pstickne
I have absolutely no issues with the mids on the Hyla TE5B. Tips, tips and tips make the difference! Try some Azla Sedna wide bore tips and the sound all comes together!
Prior to the CE5B, I was all for silicon tips and an 'airtight seal' (which, face it, is required for any BA-bass presence). The Hylas appear to fit my ears too well and the super easy to create airtight silicon seal created a serious headache-inducing pressure issue for me.
So, I guess my questions:
How does the Azla fit compare to Spiral Dot and/or Type E in terms of sizing/fit?
Do the Azla's create an airtight seal?
Tried/recommend the 'pin prick' trick on silicon tips with the Hylas?
Have another method to manage the pressure/seal differential?
