ROBSCIX
- Aug 25, 2005
Your RMAA measurments are limited but what does that have to do with the output of either card? -Nothign as the RMAA results are not accurate representations of the card.
If you measured both cards with RMAA properly the STX and ST would still give much better numbers because of the DAC on both cards.
The HALO output of the HALO is spec for about 117db.
The STX and STX's DAC output is spec'd for about 124dB which is quite the difference.
Look it up. The STX ans ST have much better SNR and dynamic ranges then the Halo, that is just a fact.
So I guess we should all stick with lower quality audio gear? Did you actually read that information before posting it? - as my guess is no.
Either that or you didn't uderstand any of it. What about 24bit audio?
Yes.....AND? Do you know what that actually means? My guess is you have no clue because you using that measurment in a wrong context and it does nothing to limit SNR of the end circuit! IF it did then the cards outputs would be limited but they are not.
Well consider the cards are entirely different(DAC,ADC's, opamps,caps) perhaps it is your gear that is producing a similar sound? -You know, your installing the same opamps, using the same headphones amplifier and the same cans.
Do you work for the site? How do you know anything about the site?
Thats right, you have no idea!
Maybe if you study up and figure out what your talking about perhaps you can put out a review!
Would be a interesting read considering all the BS your trying to shovel now!
Originally Posted by leeperry /img/forum/go_quote.gif "superior SNR"? these are the RMAA measurements for the Claro Halo lineout: and just like the STX in a loopback in RMAA, the SNR figure is most likely limited by the ADC. |
Originally Posted by leeperry /img/forum/go_quote.gif anything >100dB is overkill anyway: iXBT Labs - ASUS Xonar D2 Sound Card |
Originally Posted by leeperry /img/forum/go_quote.gif and most op-amps have a max CMRR of 100/110dB. |
Originally Posted by leeperry /img/forum/go_quote.gif I've tried these 3 cards(Halo/ST/STX), they sound very similar(same DSP/same HP amp)...and the CMI8788 is really not great for games, go X-Fi if you're a gameholic IMHO. |
Originally Posted by leeperry /img/forum/go_quote.gif also xbitlabs says that the Xonar suck at 44.1kHz: Universal Soldier: ASUS Xonar D2 PM Sound Card Review (page 13) - X-bit labs and they said that it wasn't fixed on the STX: Two in One: Asus Xonar Essence STX Sound Card Review (page 8) - X-bit labs this russian site doesn't get bribed to publish review tests that look like press releases...for a change |
