Dominat0r
Formerly known as HighLife
- Nov 8, 2006
i thought ground loops only happen if the device is turned on or power running through it.
My hum only happens when my amp is OFF. If i turn it on, the hum goes away.
So no danger in running a different bias for my tubes?
Also, i guess my CBS Fk6s are worn out...cause the new ones you sent me nate dont suffer from the same distortion as mine.
Sounds much much much cleaner...even though both sets have exactly the same markings, printed the same and in the same spot. Just the ones i have have a smaller flash getting then the ones you sent me.
