Okay everybody here are my Emmeline op amp impressions on a XP-7
Please note that I didn’t listen to most of these op amps for an extended period of time nor did I do A/B comparisons. There are likely many differences that I totally missed, exaggerated or even made up (not on purpose, of course, but I worried what would happen if two op amps shared the exact same sound only I didn’t realize it). I spent only about 30 minutes with each op amp listening to the same collection of about twenty songs. So consider my comments to be short impressions, not a full-fledged review.
The rest of my testing rig consisted of an E-MU 0404 soundcard connected to the XP-7 via Headphile copper interconnects. For phones I used the HD595s since I think they pair a little better with the XP-7 than the HD600s (the slightly thick sound of the XP-7 pairs very well with the slightly thin sound of the HD595s)
Well, with that out of the way onto the impressions-
797s--Many have found them to have a warm and a slightly aggressive sound signature. I agree, these op amps have a warm, golden coloration and give the Emmeline a little more get-up-and-go than many of the others. The also feature slightly softer sound than many of the other op amps and give a little more bloom to the sound which is just perfect and sounds realistic (more so than any of the others in this regard). Detail is great and nothing seems recessed or accentuated across the frequency spectrum. Very nice and natural sounding, if perhaps a little on the blurry side.
627s--smooth, fuzzy sounding, sounds a little softer and laidback than the 797s, has an accentuation somewhere in the lower-midrange, slightly more neutral tonal character compared to the 797s (a surprise), not as good with detail or separation as the 797s, Overall produces an decent sound but it’s not my cup of tea.
8065s--Just as detailed but a little denser sounding (ie less has less bloom) than the 797s. Also these are a little on the laidback side and have a slightly dark tonal coloration (no hints of gold like the 797s provide). Frequency response in great except for the bass being just slightly recessed (relative to the other op amps). Overall a great alternative to the 797s but I find them too laidback for my taste.
825s--these op amps sound weak, instruments don’t sound as large as with the other op amps nor does the soundstage. The sound is a little congested and the overall sense of detail is pretty subpar. Definitely the most neutral of all the op amps but they’re unable to capture the correct texture of instruments (evident with acoustic guitars). Also weak in the bass. About middle of the road as far as transparency/body balance goes. I didn’t like these at all; they couldn’t make the performance come alive and sound convincing.
604s--Reminds me a mixture between the 8065s and the 797s-it has the tonal character of the former (slightly dark) and the attack of the latter (slightly aggressive). Nice detail, balanced sound across the frequency spectrum except the bass seemed a little boosted. Perhaps a little too much body, the sound could use a little more transparency. Overall in the same class as the 8065s and 797s
LT1028--something was really off with the soundstage of these-sounds weird but they almost made performers sound as if they were performing in a very large box-the soundstage would expand only until they reached the borders of the box then stop. Besides that the bass is a little lean, tonal character is a warm gold like the 797s, detail and seperation are mediocre--the sound is a little congested and there isn’t any blackness between the notes instead that warm gold coloration permeates everything. Transparency/body balance is middle of the road. Overall I found these to be poor performers--due to the weird soundstage and lack of blackness between notes I just couldn’t enjoy them.
LT1115--A lot like the LT1028-weak in the bass, same golden tonal character and transparency/body balance only didn’t have the weird soundstage problem, was a little darker in between the notes (still some coloration there, though) and fairs a little better in detail and separation. Only average at best.
8610s--Unfortunately I didn’t get to try these since a leg on one of them broke before I even took a listen. Sad, I really wanted to hear these.
So overall I recommend these--
797s
8065s or 604s (depending on whether you feel like a slightly more laidback or upfront sound)
I think these are decent-
627s
LT1115s
I would not recommend these-
LT1028s
825s
Remember, though, to take my comments with a grain of salt as I didn’t spend that much time with each op amp or compare them to each other in A/B comparisons. It is very likely that I could be totally off with many of my comments. I just don’t have the heart to go through an in depth comparison of these op amps especially since I’m seriously considering selling my XP-7.
