bogi
- Mar 16, 2013
All additional cable endings, plugs, connectors add reflections because of not perfect impedance match. Front panel USB ports are known to perform worse than back panel ones connected directly to motherboard because of EMI inducted to cable lead in computer case. These things may be not observed with usual computer devices.
From point of view of possible reflections it is better to use 1.5m USB cable than 0.5m one particularly if cable is not terminated correctly. It is about signal rise time (tens of ns) in relation to signal transmission speed through metal wires (slightly less than speed of light).
Even if there are no dropouts, USB can still significantly affect sound by transferring computer generated noise or ground loop currents to DAC. I have very good experience with Topping HS02 followed by two iSilencer+ (together about 200 EUR). Others like improvement brought by Intona USB isolator.
