How to stop USB noise in my DAC from my Laptop (mac)
post-13229273
Post #76 of 93
Indigo Bob
I'm sorry for my absence.  I have been a bit swamped for school and making time to be able to go to canjam this weekend.
I will continue to pursue this once I am caught up on my work.
I am grateful for the help you individuals have offered and I am sorry to be out of contact lately and for the near future.
BOB
post-13229476
Post #77 of 93
U-3C
BOB
No need to apologize. ^_^
We all have lives. Do whatever you need to do first.
This is just a weird place on the internet where people get obsessed over music players for some reason and pay millions for then. :p
post-14616402
Post #78 of 93
Synthax
Any solution? :)
I have static noise, very little but audible always when I plug usb cable to Macbook Air. Mac i battery powered, cable shielded. No noise whet IPhone is used as source for usb dac (Moon 230HAD). No noise whet other usb devices plugged in...
What is wrong with Air?
post-14616431
Post #79 of 93
bigshot
Hollywood USA
Hollywood USA
Website
www.facebook.com
Can you take it to an Apple store for a checkup?
post-14621011
Post #80 of 93
Synthax
Macbook Air I have is 7 years old. The cost of official check would be high. And in my opinion it is not worth. All other usb gear gear work OK with these usb ports. The music sound right except this little noise (to me it sound like a very little pink noise). During last days I have found a users having that issue with Airs. Maybe some IFI stuff can solve the problem but I have to check it before buy.
I have no noise with Ipad and Iphone as sources to DAC but the dynamics and overall quality is unfortunately lower than with Macbook. Mac runs with the battery. So for now I have only idea that Macbook usb architecture is bad engineered in this model...
Is there any possibility to check it with software level?
post-14621049
Post #81 of 93
bigshot
Hollywood USA
Hollywood USA
Website
www.facebook.com
It sounds to me like a hardware problem. If you play an MP3 off the Mac's hard drive through the headphone out is the sound there too? If not, that would be a good workaround.
post-14621180
Post #82 of 93
Synthax
With headphone jack output is is completely silent.
post-14621197
Post #83 of 93
Whazzzup
Toronto, Canada
Toronto, Canada
Stop using a computer and use a high quality server
post-14621208
Post #84 of 93
Synthax
Which models do you recommend to not spent to much $ ?:)
post-14621216
Post #85 of 93
Whazzzup
Toronto, Canada
Toronto, Canada
I can’t say as not cost much and quality server do not compute. Folks try diy cheaper end routes with raspberry pi etc, I don’t know anything about those. I have a thread to antipodes DX butthats way out of your range, shame cause they do make a difference, but all servers are not the same.
post-14621850
Post #86 of 93
bigshot
Hollywood USA
Hollywood USA
Website
www.facebook.com
Just play it using iTunes on the Mac if that sounds clean. The internal DAC in Macs are every bit as good as external DACs.
post-14625757
Post #87 of 93
ginetto61
Milan _ ITALY
Milan _ ITALY
post-14805369
Post #88 of 93
JulienS
I have the same problem, noise through all the USB outputs into my DAC. I noticed that happens only when the notebook is connected to the mains. When it is on battery, all the USBs are totally silent.
Any ideas how to solve this? Thanx
post-14805575
Post #89 of 93
sonitus mirus
For ground loop issues, I would recommend placing a standard version Intona usb 2.0 hi-speed isolator between your notebook and DAC. It may not resolve your specific problem, but it is no gimmick and it certainly might help.
https://pro.intona.eu/en/products/7054
post-14844408
Post #90 of 93
JM1979
North Carolina
North Carolina
A cheap solution to try is the Audioquest Jitterbug. I had success with that in the past.
