WindowsX
Member of the Trade: Fidelizer Audio
- Apr 27, 2007
Sorry you didn't read the thread.
What he has is interference from the WiFi card. That would be a flaw in the DAC design, and not all DACs have the problem. It's not the MacBook, as this would be the same issue with any computer with a healthy WiFi card and those DACs. In fact, I have a MacBook Pro, and have a DAC sitting right next to it, on the side the WiFI antenna is located, and no problems. Not the same DAC, though.
I did suggest he move to cables next, but then he discovered turning off the WiFi card cleared the problem. He also said that putting the DAC on a longer cable and moving it away from the computer reduces the problem. That would indicate that the problem is RFI from the WiFi card entering the DAC directly, not via the cable. A longer cable makes a better antenna, not a worse one.
Yes, he could try a shielded USB cable. I'm doubtful it will help, as the symptoms don't strongly indicate the point of RFI entry is the cable.
That sounds like some interference that can be improved with shielded cable if you ask me. If your assumptions are correct, using DAP as a standalone unit should also have this problem. I doubt putting DAP next to macbook will have the same issue. Let's see if using shielded cable helps or not.
Well, it's not ground loop as you're so sure of so I recommend you to stop jumping your guns to conclusions that might be wrong. Or are you still on about ground loop stuff?
