- Jan 9, 2003
To me, a top notch speaker setup will amaze you as much with metal as it will on jazz, perhaps even more so. If it doesn't handle metal well, then I'm not interested
Metal is difficult because the speakers need:
* To be very coherent in phase and timing from top to bottom
* Very fast
* Very well balanced/integrated in the frequency spectrum from top to bottom - too much to one side or the other and the resultant muddiness, shrillness, or scooped-mids become VERY apparent
* Excellent dynamics, to avoid sucking life out and sounding sterile or analytical
That's a hard combo to optimize for. Add in the difficulty of finding an appropriate amplifier for when your speakers are of lower efficiency and/or have a weird impedance curve!
It's also very difficult on the room acoustics - the barrage of noise is too much for many rooms that would do perfectly fine with simpler music. A good room is a true luxury these days.
Once these factors are soundly addressed, you'll hear that the typical hard rock and metal recordings aren't as nearly bad as they say - in fact many are quite excellent (at least on vinyl)! The problem is, it's very difficult and often expensive to address the above issues in a speaker setup, when it can be accomplished (sans the wonderful attributes of staging and visceral presence that good speakers bring to the table) in a headphone setup at a much lower price - full range from a single crossover-less driver for perfect coherence, and freedom from room effects!
I've lucked out in the last year and found/obtained my "dream" room and speakers, but it wasn't easy nor cheap. I went through some very nice speaker gear the past few years, and still listened to mostly headphones until I just recently got the right speaker ingredients together. Only now, do I realize I can finally live without the high-end headphone gear - it's finally lost its magic in the face of my treasured speaker setup.
Still - man, I was a difficult convert over to the speaker-side
* Very fast
