headdict
The frequency on the upper left will scroll up in the video and the frequency corresponding to the scrolling number will play. If at some point of the video the tone suddenly sounds too loud, take a note of the number scrolling in the video--that's the range of frequencies you have to tone down using Electri-Q. Vice versa, a part that sounds too quiet is a part you have to tone up using Electri-Q. There are frequency indicators on the horizontal axis of Electri-Q, and if you double-click on a point you can even enter a specific number. Look further down the tutorial for further instructions on Electri-Q
This works great for "local" problems such as peaks and dips, but what if there is a gentle rise or decrease over a number of octaves? The overall balance can still be way off, if I follow this method. Am I supposed to make wild jumps through the video to find out about such problems? How would I be able to correct those in a systematic way? Or, in other words: Would you mind to provide us with a set of pre-rendered test tones like Lunatique did, but using the same generic equal-loudness contour?
By the way, I'm using the TDR Nova AU plugin in AU Lab. I redirect the output of a regular video player via Soundflower. The free version of Nova supports four bands, while the commercial one adds another two. I can use more than one instance to work around that limitation, but it's very awkward. If anyone can recommend something more capable for Mac, I would appreciate that as well.
Nova has a built-in spectrum analyzer, so I don't really need the video to display the current frequency, but it's a great idea and can be extremely useful for other applications.
