Originally Posted by linuxworks /img/forum/go_quote.gif
but at that point, since dual xlrs are not really standard and 4 pin 'xlrs' are also not standard for audio use, you might as well just pick ANY 4 pin jack and plug pair. why try to force xlr to doing things it wasn't meant?
but the XLR plugs lend themselves SO nicely to this kind of application.
They all have very high (as far as signal levels are concerned) voltage tolerances, very high current capacity, and they dont short themselves when plugged (unlike a TRS)
4 pin mic jacks are probably the cheaper and easier way to do this. I'm confused why people think a single 3pin xlr jack is 'good' for 2 channel audio (boggle..) |
I agree, using a single 3-pin for stereo is dumb. it is simply begging to find problems which will quickly be encountered. I think I have seen a single 3-pinXLR used for front and rear of a 4-channel reel-to-reel tape setup, but im pretty sure it was a secondary application using parts that were already being used for the main 2-ch balanced outs.
RE microphone connectors:
older headphones came with DIN connectors as an option, which shares many cool features with an XLR. They could be used with equal success as an XLR in a headphone amp, but it would be something of a unique solution which brings many problems when you try to share your gear with anyone else.
I guess the 4-pin microphone plugs could be used as well, although I dont think they are that much less expensive than a single 4-pin XLR solution and again are somewhat unusual for a headphone app. The screw-down collar always bothers me in an app where quick connections are a benefit. I like the ability to switch headphones with a press of the locking button, and a gentle tug. The screw-down connectors dont hold down worth anything if the screw down collar is not locked.
