KeithPhantom
Your first question can be only answered by an objective test, which is pretty hard to do. Double blinds with different headphones are pretty hard for many reasons, and this is the reason we leave this to preference. The second one, better in terms of audio perception is subjective, thus, there won't be any consensus that can represent a statistical majority. You evaluate your priorities and choose with them in mind.Ad 1: There are some less controversial differences, e.g. 2 $ earbuds that sound like a tin can or the difference between a Meze Empyrean and a Stax SR-009s when playing a bass heavy pop song. But then there is a large middle ground where I would not be so sure of my hearing.
- If I hear a difference between two headphones: Is there really a difference?
- After I convinced myself that two headphones sound different: Which sounds "better", i.e. which shall I get?
Ad 2: Chances for a scientific answer on 2. are slim, even lower than for 1.
@RickInHouston even pointed out that chosing the headphone which has the "sound I want" may not be wise.
There is one headphone for which I am inclinded to think that 1. there is a difference and 2. it actually sounds "better" than the others is the Stax SR-009s - if bass heavy pop songs are excluded for the moment.
(I exclude also the Sennheiser HE-90 and HE-1 here because they are too pricey.)
Which still leaves the amplifier choice for the Stax open. I will have to be careful to not fall for amplifiers that are expensive without audible benefits.
Nevertheless, if you have further good advice on choosing/comparing headphones and avoiding expectation bias, I am looking forward to read it here.
After all, the 009s is a significant investment, so I will not buy it in the next few days.
If you want one of the most objective ways to compare headphones is to read measurements. They're usually not perfect due to problems in compensation curves and equipment, but, they are a starting point. You can define better by getting transducers with low distortion and a good FR that correlates with what you're looking for.
