Originally posted by sTaTIx
I don't trust my own ears very much. And to be quite honest, I feel that most audiophiles trust their own ears TOO much. |
I'm really sorry for you about your lack of self-conciousness. Pity if you're deducing from this that others should be like you in this regard. I don't know many audiophiles except me, so I don't know if your criticism is justified, but you may nevertheless be right to a certain degree.
Have you read that one Stereophile review who felt that the Grado SR60 provided 90% of the sound of the HP-1? |
I'm absolutely not in the US hi-fi magazine scene. But this judgement is ridiculous by all means. 90%!
I even don't know the HP-1, just the recent models up to the SR-325, but this says enough to me. Surely I wouldn't call such an author an audiophile, and I can imagine this one would even call a $120 CD player 90% of the top Mark Levinson transport/DAC combo.
Most people are mostly full of ****. But some people just don't realize it. |
Sorry, I just don't know what «****» is (in this context).
I beg of you to ask yourself this question: is there even an iota of a chance that your findings of differences between transports were ********? |
I've done it, even several times. Not so much in the last time though.
Originally posted by Solude
The core problem with audiophiles and digital is that people can't remove themselves from the fact that it's just data in the digital domain, not sound. |
Do you see «audiophiles» as a conspiring group? For me each audiophile is a unique person with individual opinions. And the fact that some (or maybe most) of them believe to hear differences between CD transports doesn't reflect in any way their ignorance in terms of digital techniques. You have not the least advantage over «us» in this regard. What you're postulating is that the pure knowledge of the 0s and 1s should prevent one from hearing what «we» hear. That's an absurd standpoint – I for one would call this a bias: to insist on a kind of self-censorship, with digital as a holy cow...
You're wrong with your statement that it's just data. It's also data
flow (which incorporates a clock rhythm). You may not be familiar with the possible effects of jitter (= data out of rhythm) – I confess I'm not as well –, but I guess it's not hard to imagine how it can affect the proper reconstruction of a music signal which in fact consists of an immeasurable amount of different frequencies at the same time which are to a certain amount dependent of an accurate and precise reproduction of their spectra. Jitter represents a shift in the time base, thus an alteration of the frequency spectrum of the concerned signal.
And there is also the data conversion (DAC) in corresponding devices. The 0s and 1s arriving here get converted into an analog curve. You know there is a bit depth of 16. This makes 65,536 steps which serve to reconstruct the signal as it was before the recording or the analog-to digital conversion, resp. It's important that every step has the same measure, meaning the same level change throughout the whole dynamic range. But that's not possible, technically. There are small to considerable deviations from linearity, depending on selection and overall quality standard. And these will inevitably further deteriorate the original signal and alter its frequency spectrum as well as its phase response and create higher-order harmonic distortion. You see: digital isn't just 0s and 1s.
So you're telling you indeed have done direct A/B comparisons. Well, it's your experience and your perception, whereas I have my own one. I don't want to put yours down. It's just my experience that it's very important to use high-resolution equipment and – first of all – a setup you know very well in a familiar acoustic environment. Whereas there's no need to attach importance to cabling and the transport section for a setup that's meant for a party, independent of the quality demands.
As I said, the sonic difference the transport makes is very obvious in my system. Actually I would really like the Audiolab 8000CDM, a dedicated, quite expensive and formerly highly acclaimed CD transport, to be the better sounding one. The quite cheap 963 SA which has assumed this role now has a rather poor audio handling convenience. After all it's (just) a DVD player. But its sound is just miles ahead of the Audiolab's...
I've made a test with my 17 y.o. son, a music lover like me, but without an explicit hi-fi background. I played his black-metal CD through my speaker rig, once with the Philips and once with the Audiolab as transport, through the Bel Canto DAC2. He preferred the more colorful and detailed sound with the Philips by a wide margin. It turned out that he believed the DACs also have been swapped, and he almost couldn't believe that pure digital can make such a difference. I wasn't surprised about his judgement, since the difference is really almost like day and night, not just subtleties. BTW that's what astonishes me a lot, too. Because I do know how digital works...
JaZZ
