what would be the point of me testing one piece of gear with the other??? can you explain that to me?? either way the results would be colored with the testing equipment. Manufacturing besides the manufacturers very own websites and boxes state measurements that are inferior to the RME. and the RME isnt even top of the range. you guys are funny just because AMB recommends it, its amazing. its reasonably cheap for what it is; IMO thats probably why its being recommended; not because its such an amazing piece of testing hardware. why would AMB recommend you guys buy an expensive piece of audio production hardware just to test amps out and not make any music with it?? any really good piece of ADC hardware would cost several times more than the amp you are testing. does that sound like something to recommend. even the fireface isnt that high end. OK guys I just looked it up and the 'audiophile' is as I thought; its the entry level of their PCI based audio cards and its still using the same chip as when I bought my delta 66 about 6 years ago. which one are you guys supposed to be using the 24/96 or 24/192?? the 192 is a BIT newer but still not new at all. the ADC specs on the 24/96 from the M-audio website for dynamic range are 100.4dB (A-weighted) (A/D). and frequency response:22Hz-22kHz, -0.4, +/-0.4dB (not even as good as the headphones connected to the gear that we are testing) with the 192 being half decent with a dynamic range:109dB @ 48kHz (A-weighted) and frequency response:+/-0.1dB, 20Hz to 20kHz @ 48kHz <-still only FR as good as an ipod. if you are trying to test something that may be outlside of our hearing then surely you should test it with something that can produce /capture audio that is outside of our hearing... wouldnt you think?? I mean my hearing doesnt reliably go up past 20khz, but play a 20khz tone and I can almost hear it and it certainly has an effect on harmonics above that. add to that the fact that this is a PCI based card and there is all sorts of noise going on inside the average computer. at the very least you would be better off using an entry level firewire or usb based interface.
the fireface (and bare in mind I wasnt recommending it for this test either; just saying that I could hear a difference) it has Dynamic range AD: 110 dB RMS unweighted, 113 dBA and Dynamic range DA: 110 dB RMS unweighted, 113 dBA (unmuted) and heres the killer
Frequency response AD/DA, -0.1 dB: 5 Hz - 20.4 kHz (sf 44.1 kHz)
Frequency response AD/DA, -0.5 dB: 1 Hz - 43.3 kHz (sf 96 kHz)
Frequency response AD/DA, -1 dB: 1 Hz - 80 kHz (sf 192 kHz)
happy??
and the fireface isnt even RME's top of the line. IMO one of the mid level M-audio interfaces (preferably not a PCI based one) would be able to tell the difference between a braided cable and one as Tomb suggests scattered. but to be honest i'm not even interested. I only bothered with this because you were somehow arguing that I couldnt hear a difference and that it wasnt valid. look at those specs and tell me that I wouldnt have been able to. my point was that if I could easily hear the difference then equipment more sensitive than my ears certainly should be able to.the audible difference (apart from more IO) was the reason I upgraded in the first place.
