tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Coming right up!
As a for instance, here's AMB's frequency response graphs of the M-Audio Transit in loopback and the Alien DAC:
Here's the same thing with the M-Audio Firewire:
Now, if one were truly interested in the response of the Alien DAC from 15KHz to 20KHz, then perhaps the M-Audio Firewire may not be enough. However, it's dubious that it would follow the loopback curve exactly if the response were not much better than the recording device.
In any event, there's much more useful info to be had from RMAA as well. I'm sure AMB could make much more authoritative statements about this than I can, but either device seems to me to be quite useful for our purposes.
Here's mine comparing the BantamDAC to the AlienDAC, using the M-Audio Transit. You can see that the FR matches the loopback in AMB's images perfectly:
More than that, here is evidence of the difference in lack of cabling between the typical Alien DAC and the BantamCableDAC (Noise):
EDIT: These are at 16/44.1 or 48KHz. The frequency response is better at higher rates, but the Alien and Bantam are not able to respond at those settings. The fact remains that the Transit has a better response at the lower rates, though. Again - so what? Either can perform these tests adequately to see what's going on with the device under test. The M-Audio Firewire is undoubtedly more convenient, though.
EDIT2: I got the BantamCableDAC/BG Alien FR graph mis-placed with one of AMB's. It should be corrected now - refresh your browser if it doesn't show as BantamCableDAC/BG Alien.
