you said many times that the headphone cannot reproduced recorded sound stage which not true.
It is true, and the Smyth Realizer doesn't prove it isn't because it isn't reproducing a recorded soundstage, it's reproducing a listening environment playing a recording.
most of us including myself does not have smyth realizer. the simplest example that i can give is a youtube recording and yes it not the best example but and it only output in stereo mode.
The youtube recording didn't prove your point, sorry.
you kept denying the fact that headphone cannot reproduced the recorded sound stage.
No, I keep saying that headphones cannot reproduce the recorded sound stage as it was intended.
i am not saying that a headphone is more accurate than real speakers with proper multi million dollar setup.
i am just saying that a headphone with like a less 1000 dollar tool, you can actually emulate the environment which means headphone is capable of listening to the recorded sound stage or in this case the emulated sound stage.
That's the first time you've said that.
But it's WRONG! Even after posting screen caps you still don't get what the Realizer does!!!!
IT DOES NOT reproduce the recorded sound stage! It reproduces a listening environment with it's own sound stage! The application, specifically, is
virtualizing a 5.1 surround listening environment on headphones. That's a VERY DIFFERENT GOAL and VERY DIFFERENT APPLICATION. In 5.1 film sound we have more closely standardized mix environments, and can, if budget allows, build a home theater that closely matches the industry standards. But that's a specific application which does not translate to two channel stereo music, where control rooms and mix environments have not been standardized. You literally have no idea what kind of system a recording was mixed on! What are you going to "realize"? The L/R speakers of that 100K home theater? It may sound good, but it won't be a replication of the original.
But your arguments are circular and make no sense. You said that headphones reproduce the recording's soundstage, and that's NOT TRUE. Then you say that everything sounded weird in headphones because you listened to speakers since birth. Then you toss in the Smyth Realizer into the discussion. Regardless of what that thing does, it doesn't change the fact that headphones, by themselves, cannot reproduce the original soundstage. There are some very specific conditions under which the Realizer can replicate the original, but they don't apply to any source you've cited so far, and since you listen to Tidal, they don't apply to that either.
