TheSonicTruth
- Dec 19, 2014
c....what if it's the other end of the spectrum of causing
you violent nausea.
Lemme have 30 seconds of of 14HZ at 90db! lolol
you violent nausea.
I'd be interested in getting clarification from your opinion. Do you believe LPs can generate measurable 60khz signals? Citations say that the best reel to reel studio masters might go from 10hz-20khz. The RIAA curve's constants are 50hz, 500hz, and 2122hz (while that is slightly higher than 20khz, I assume it's still for mathematical reasons). Most people say they prefer vinyl due to distortion (IE digital being bright, and vinyl having some rolled off highs). Especially since an LP's source in the best of circumstances gets to 20khz, I can't see how 60khz wouldn't just be random.
When it comes ultra-high frequencies enhancing music, I have never seen any scientific consensus that has suggested this. I've taken neuro-anatomy and can appreciate the physiology of the brain. The main consensus I've seen is that there can be activity in the thalamus, but it's inconclusive as to any perception a person might feel. And honestly, if you're making the leap that ultra-high frequencies can add some kind of euphoria to music....what if it's the other end of the spectrum of causing you violent nausea.
What I am saying is that I believe there may be higher frequencies contained as part of transients.
What I am saying is that I believe there may be higher frequencies contained as part of transients. Fourier analysis tells us that a simple square wave contains an infinite number of frequencies when broken down into frequency components. So my question is : are there wave-forms in music that when broken down may yield similar results. Music is not a simple sine wave. As I said - I am investigating this and using CAT5E was just a starting point.
Well previously, I mentioned I did like SACD and high res blu-ray concerts: but I think it's more that they are less likely to be compressed and are approximating studio masters. If you look at the fundamental FR of instruments, they are clearly below 20khz, and you're getting into harmonics (of which, sure you can keep going logarithmically up mathematically, but from a reproduction standpoint, I think it still diminishes). I'm no sound expert...but I've read the argument for high-res formats isn't so much realistic modeling of ultra-high frequencies, but no distortion within the audible spectrum.
Interesting, and I think CD/SACD have to roll off due to the low pass filter used to recover the analog signal. The only CD player I have heard that sounded half way decent to me was my old Rotel RCD-855 (God rest its soul).
The filter on CD players is applied above your ability to hear. Every CD player I have ever owned sounds identical. I do controlled listening tests with every piece of equipment I buy to make sure it is audibly transparent.
I think you've misdiagnosed your problem. I think you have a frequency response imbalance in the high end somewhere.
It seems to me that you're referencing a component's "musicality" than actual measured specs (and something that wouldn't gain acceptance in "Sound Science"). Back when SACD didn't allow digital output, I got a high end stereo player, that also up-samples CD to 192khz. I've really liked it. When I took it to a friend's house to audition (he himself being a vinyl head), he mentioned he was unimpressed. Now that I have a receiver that handles DSD, I can also output digital DSD from a BD player. To me, it sounds more clinical than my high end player, but the digital config gives me the surround layer. I'm probably a purist when it comes to being an audiophile. I do have a vinyl collection, but it's with classic rock: back when the original masters for vinyl were better than later issues for CD. For new music, I get digital. I guess what I'd say is that any component (analog or digital) is going to have some subtle differences due to design. I have yet to see any articles that confirm there being sources that can generate pure 60khz tones.
The harshness is probably coming from a frequency response imbalance in your room and speakers, not digital.
Well I did provide specs on the tweeter and cartridge. On that note - if we assume that engineers at KEF and Denon are not stupid, why do you think they would produce components with responses above 40KHZ?
I thought I was already inferring it: I don't think that it's a coherent response above 40khz, but that there's chance for no distortion at 20khz.
