d-cee
- Apr 14, 2006
http://www.head-fi.org/forums/f4/w10...23/index2.html
it was here in the PDF linked in the original post, but it appears to have been taken offline since the original post was several years old
anyway the concept is simple, go down to your hardware shop. look for some rubber tubing/piping
not sure about what size/diameter, may need to experiment and then cut it to length so that when you put it in a circle it just fits inside your earpads
you don't even need to take off your earpads you just slide it between the earpad and the headphone body and that's it, your ear pads and now much fuller and keep your ears from touching the driver
Originally Posted by inasafeplace /img/forum/go_quote.gif d-cee thanks for the advice, could u direct me to the place where u saw any demonstration of these "fat pads"? I couldnt find... |
