dprimary
- Jan 11, 2015
I think it's worth noting that the amplitude scale is measured in dBr, AKA decibel reference value.
Disadvantages of decibel reference value, excerpt taken from Wikipedia
According to several articles published in Electrical Engineering[26] and the Journal of the Acoustical Society of America,[27][28][29] the decibel suffers from the following disadvantages:
The decibel creates confusion.
The logarithmic form obscures reasoning.
Decibels are more related to the era of slide rules than that of modern digital processing.
Decibels are cumbersome and difficult to interpret.
Representing the equivalent of zero watts is not possible, causing problems in conversions.
Hickling concludes "Decibels are a useless affectation, which is impeding the development of noise control as an engineering discipline".[28]
Another disadvantage is that quantities in decibels are not necessarily additive,[30][31] thus being "of unacceptable form for use in dimensional analysis".[32]
http://en.wikipedia.org/wiki/Decibel
Like I said it's all BS
http://whalerider.bandcamp.com/album/was-it-only-a-dream
Was it only a dream
If not a in dB then what? Linear scale is not that useful in audio. You can convert it to pascals at 50dBSPL your 15 dB variance in your response will now range from 6,000 uPa to 35,000uPa now you are linear and absolute.
dBr when comparing frequency responses is the correct way if you are planing to compare. Since the 0dB mark is in the center of the graph we would think that is not an absolute.
The argument to use pascal instead of dB make little sense. The general public doesn't understand dB scale so we should pascals? They may not understand decibels but they have never heard of pascals. Hickling really needs to get out of the lab. Then as soon as you leave acoustics you have change back to dB. You can't change the gain of a circuit by 20,000 uPa, it is an acoustical unit. Since I talk to acousticians often I will ask them for everything in Pascals just to see the response.
