Jan 21, 2010 at 8:55 PM Post #632 of 771
Shipment arrived!
1 Thunderbolt Max headphone amp
1 DAC-Extasy DAC
It's obviously way too early to make any really useful comments, but I turned angle_shooter on to the T-bolt Max sight unseen, based only on the excellent SQ and performance of the RM-1, so just wanted to say to that I think you are going to be *very* happy that you went with this amp. Even out of the box this thing has met if not exceeded my initial expectations. "Sounds good, man!"
Now I'm just going to give it a hundred hours or so of burn in, along with the nuforce uDAC (though someone said that didn't really change much after even 1 month of burning in), and then do some comparisons. Both DACs compare VERY FAVORABLY so far - it looks like we have two strong winners on our hands - but I don't want to get too ahead of myself. On to burn-in.
cheers dave!
Jan 21, 2010 at 9:02 PM Post #633 of 771
Does the Extasy have a headphone out or is it a pure DAC like the DAC Straight?
Jan 21, 2010 at 9:05 PM Post #634 of 771
It has a headphone out.
Jan 21, 2010 at 9:11 PM Post #635 of 771
Nice. Looking forward to your Extasy/uDAC comparisons, since they seem to be in the same category (performance, design, and hopefully price wise).
Jan 21, 2010 at 9:31 PM Post #636 of 771
I simply can't believe the price performance ratios that are available these days. I'm sitting here listening to these DACs, and I'm just marveling at the high quality that's out there for the money today. There's nothing "budget" about this gear at all -- all except for the price, that is. And that's the way it should be, imo!
Jan 21, 2010 at 11:28 PM Post #638 of 771
hmm, this is strange. dmesg is reporting the DAC-Extasy as a Burr-Brown TI chip - is the "wolfson" just a varient or subcategory of Burr-Brown?
V-DAC: Quote:
input: Burr-Brown from TI USB Audio DAC as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.2/input/input38
generic-usb 0003:08BB:2706.001E: input,hidraw0: USB HID v1.00 Device [Burr-Brown from TI USB Audio DAC ] on usb-0000:00:1d.1-2/input2
uDAC: Quote:
input: Vendor strings are placed here. Nuforce µDAC as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.2/input/input39
A48.001F: input,hidraw0: USB HID v1.00 Device [Vendor strings are placed here. Nuforce µDAC ] on usb-0000:00:1d.1-2/input2
DAC-Extasy: Quote:
input: Burr-Brown from TI USB Audio DAC as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.2/input/input40
generic-usb 0003:08BB:2705.0020: input,hidraw0: USB HID v1.00 Device [Burr-Brown from TI USB Audio DAC ] on usb-0000:00:1d.1-2/input2
Whatever it is, it sounds pretty good, but I was under the impression this was a wolfson-based DAC.
Jan 22, 2010 at 12:04 AM Post #639 of 771
V-DAC:
uDAC:
DAC-Extasy:
I use a TI chip to do the USB to SPDIF convertion, then a DIR9001 to do the I2S convertion, then on to the WOLFSON DAC
You get the best of all possible worlds, as well you get the longevity of the TI chip for future upgraded of WINDOWS OS....
I am wondering....
Does it sound better now that you know it has a WOLFSON DAC ?????
hotaudio40
Jan 22, 2010 at 12:24 AM Post #641 of 771
hotaudio40
Okay - sounds good - thanks for explaining.
And when I say "sounds good," it sounds good! For everyone who has been following the uDAC thread, we are talking here about another DAC that is easily in the same class as the nuforce. Definitely apples to apples. They each just have a slightly different flavor, as we would expect from the different chips. The V-DAC (at 3x the price) is more expansive and revealing than both, but so far, with minimal Extasy burn in, these two seem to be in the same league, just voiced a little differently. I am totally liking what I'm hearing.
But I've gotten in enough trouble over the past few days, so I'll shut up now until all burn-in and evaluating is complete.
Jan 22, 2010 at 12:31 AM Post #642 of 771
lol, yes, you have to use differnt headsets, music, etc.... even times of day, as we all know the power supply mains are much quieter at night....
That's when the music really takes on a new "sweetness"....
lol
Jan 22, 2010 at 6:01 PM Post #644 of 771
hotaudio, there are TI burr-brown chips that do USB to I2S. Was there a reason to go TI USB > S/PDIF before using another chip (DIR9001) for the I2S conversion? I'm just curious, not trying to bust your balls or anything.
Jan 22, 2010 at 6:55 PM Post #645 of 771
Of course there was a reason
I thought I would go with one of the most popular TI chips that had the USB to SPDIF function, that way in case somebody where to say, oh I don't know, maybe use a different version of windows say... then the DAC would still self install....
Basically to protect my DACs' shelf-life and usability between all the different OS'es out there....
Since I don't, and probably can't write my own drivers, I rely on the built in Windows drivers, which is probably a better idea anyways...
So going with the most popular CHIP just seemed like a good idea....
I had looked at TI's little USB to SPDIF chip and thought about using it as well...
I can't remember the number off hand, but it looked like a nice little unit
And of course TI also sells chips with built in USB to I2S functions as well, and they are very nice
But I just went with this option.
There are SO many options out there...
Oh yes, And I also wanted to use the DIR9001 chip, it is VERY expensive compared to the rest, but I'm pretty sure its' limited 'jitter' makes it worth the extra bucks...
I didn't really believe that "you" could hear a 20ppm difference in jitter, but I think I was wrong...
You VERY MUCH CAN hear the difference, and in another SPDIF ONLY DAC I make, it is even more pronounced as that particular DAC (which I can't name) has a 'wave shaper' or 'buffer' stage for the incoming SPDIF signal.
That buffer "squares up" the digital information before it is feed to the DIR9001....
And here AGAIN, you CAN hear the difference it makes.... just feeding the SPDIF to I2S converter nice clean square waves....
Who would have thought....
hotaudio40
