does anyone know how well any of the hotaudio40 amps/dacs perform with k701s?
hotaudio40 's amps
- Thread starter misterDX
K_19
- Sep 29, 2008
I'm actually thinking very hard about buying the DAC Straight so if I do get it, I will let you know. It would be on some serious K701/HD650 duty.
Speaking of which, the only thing that has been holding me back from purchasing it is because I'm not sure how much of an improvement DAC straight will be compared to my current Total Bithead (feeding the EF1s). I've read from this thread that Hotaudio stuff + EF1 is good in general, but can anyone that have experience with both bithead and DAC straight (or even reasonably speculate) tell me if it is indeed a significant enough upgrade?
Originally Posted by midget /img/forum/go_quote.gif does anyone know how well any of the hotaudio40 amps/dacs perform with k701s? |
hotaudio40
Member of the Trade: hotaudio.com
- Feb 17, 2008
The DAC STRAIGHT can NOT drive headphones directly!!!
It needs a headphone amplifier as a buffer between it and the headphones as it is ONLY a DAC, not an AMP!!!
Just thought I would make that clear as some may think it can drive headphones.
It can NOT drive headphones!
Originally Posted by K_19 /img/forum/go_quote.gif I'm actually thinking very hard about buying the DAC Straight so if I do get it, I will let you know. It would be on some serious K701/HD650 duty. Speaking of which, the only thing that has been holding me back from purchasing it is because I'm not sure how much of an improvement DAC straight will be compared to my current Total Bithead (feeding the EF1s). I've read from this thread that Hotaudio stuff + EF1 is good in general, but can anyone that have experience with both bithead and DAC straight (or even reasonably speculate) tell me if it is indeed a significant enough upgrade? |
K_19
- Sep 29, 2008
Yes, I'm well aware of that. If you read my post above you'll see that I'm planning to feed my EF1 headphone amp from it.
Sorry if that was confusing.
Will the components used in DAC Straight be superior to the ones used in the DAC component for Total Bithead? That's the question.
Originally Posted by hotaudio40 /img/forum/go_quote.gif The DAC STRAIGHT can NOT drive headphones directly!!! It needs a headphone amplifier as a buffer between it and the headphones as it is ONLY a DAC, not an AMP!!! Just thought I would make that clear as some may think it can drive headphones. It can NOT drive headphones! |
Hey guys, I have a question.
Say I want to use the destroyer with my mini^3 amp. If I use a mini-mini to connect my mini^3 to the destroyers headphone output, would this mean I'm amping the signal twice? Hence its not optimal? Thanks
UTF
- Nov 3, 2004
I am also thinking about the same thing, to feed EF1 with hotaudio and then to HD600. In addition to how much it will improve over what i am using now (m-audio transit), i am also debating between different modes, straight or bitperfect or destroyer. In general i like a warmer sound, that is said coming with destroyer, but it seems straight may be a better DAC. Any comment?
Also, how is the hotaudio stuff (say straight) compared to fubar II or ibasso boa, which are also my current considersations?
Originally Posted by K_19 /img/forum/go_quote.gif Speaking of which, the only thing that has been holding me back from purchasing it is because I'm not sure how much of an improvement DAC straight will be compared to my current Total Bithead (feeding the EF1s). I've read from this thread that Hotaudio stuff + EF1 is good in general, but can anyone that have experience with both bithead and DAC straight (or even reasonably speculate) tell me if it is indeed a significant enough upgrade? |
CTechKid
- Oct 11, 2004
The Burr-Brown PCM2702 in the DAC STRAIGHT is a superior DAC than the PCM2902E in the Bithead. How much better? I'd say considerable.
Originally Posted by K_19 /img/forum/go_quote.gif Yes, I'm well aware of that. If you read my post above you'll see that I'm planning to feed my EF1 headphone amp from it. Will the components used in DAC Straight be superior to the ones used in the DAC component for Total Bithead? That's the question. |
CTechKid
- Oct 11, 2004
IMO the DAC STRAIGHT is HOTAUDIO's best DAC, assuming of course you're feeding it into an amp. He's setup it up so the PCM2702 is totally raw in its output, and thus has no buffering or any kind of modification, and thats a considerable plus in my books.
Originally Posted by UTF /img/forum/go_quote.gif I am also thinking about the same thing, to feed EF1 with hotaudio and then to HD600. In addition to how much it will improve over what i am using now (m-audio transit), i am also debating between different modes, straight or bitperfect or destroyer. In general i like a warmer sound, that is said coming with destroyer, but it seems straight may be a better DAC. Any comment? Also, how is the hotaudio stuff (say straight) compared to fubar II or ibasso boa, which are also my current considersations? |
K_19
- Sep 29, 2008
Nice, thanks for that information. Looks like DAC straight will be my next purchase on my next paycheque (which is tm). Luckily it's on sale at the moment too, and also in-country sale which is always convenient. I can sell off the Bithead and make some of that money up anyway, since I have EF1 now and have no use for the amp portion of the Bithead. Costs are adding up, but hey, I've come this far so I might as well maximize my setup.
Originally Posted by CTechKid /img/forum/go_quote.gif The Burr-Brown PCM2702 in the DAC STRAIGHT is a superior DAC than the PCM2902E in the Bithead. How much better? I'd say considerable. |
powerslave
- Dec 26, 2007
Yes, that would be considered double amping. You could introduce unwanted distortion and/or damage the 2nd amp if you raise the volume on the first amp too high. Check out this thread for reference http://www.head-fi.org/forums/f5/double-amping-391361/.
Originally Posted by chews89 /img/forum/go_quote.gif Hey guys, I have a question. Say I want to use the destroyer with my mini^3 amp. If I use a mini-mini to connect my mini^3 to the destroyers headphone output, would this mean I'm amping the signal twice? Hence its not optimal? Thanks |
powerslave
- Dec 26, 2007
Welcome back!
userlander
Banned - aka walrus1 - aka vidranger1 - aka iggy-starnuts
- Mar 3, 2009
x2
Welcome back, Dave!
Originally Posted by powerslave /img/forum/go_quote.gif Welcome back! |
x2
Welcome back, Dave!
K_19
- Sep 29, 2008
Would what I am currently running right now (laptop -> usb -> bithead -> mini to rca -> EF1) fall under the same category? In my setup bithead is running as a DAC but I'm not sure if by using Bithead's headphone out as an output for mini to RCA I'm essentially doing the same thing (or if it is a different case with DACs). Just want to make sure so that I don't do damage to my EF1 before I get my DAC straight.
Originally Posted by powerslave /img/forum/go_quote.gif Yes, that would be considered double amping. You could introduce unwanted distortion and/or damage the 2nd amp if you raise the volume on the first amp too high. Check out this thread for reference http://www.head-fi.org/forums/f5/double-amping-391361/. |
powerslave
- Dec 26, 2007
If you are using the headphone out of the bithead then yes you are double amping currently. I'm not familiar with the bithead so i don't know if it has line level outputs. You should maybe check with the manufacturer to see what they suggest. I know i did it with my hotusb1 to and amp via headphone out so i could get more power to my phones. I asked dave about it and said it was ok to do so and i had no issues. I did notice though that if i turned the hotusb1 up too high that the sound would get a bit muddy, not as clear. I think in this case, the hotusb1 doesn't produce alot of power to begin with so no danger of harming anything downstream. Not sure about the bithead though.
K_19
- Sep 29, 2008
Yeah, the Bithead does not have a separate line out, but I do remember reading the FAQ from Headroom that said while it doesn't have a separate line out, headphone out is just as good except for a little bit of distortion being possible. It does not mention anything about double amping. I don't listen to particularly loud volumes (my Bithead volume is set around 3/4 while my EF1 is around 10 o'clock) or anything, so is it safe to assume that it's relatively safe for now without risk of overloading?
Edit: Here's what the FAQ says.
13.Q. Does the BitHead have a separate line out?
A. No, it does not have a separate line out. You can use the headphone jack with confidence though; remember that, as a general rule, headphone amp outputs are just like good pre-amp outputs but typically just a bit noisier in terms of adding some background noise floor issues.
