swtnate
Imma bout to flood you with project ideas. lolMy inbox is always one click away for you my man!
only caveat, we have to internationally copyright our IP like the Godfather @piotrus-gMy inbox is always one click away for you my man!
Excellent work as always..and yes I agree about the bass. I always seem to be seeking more from my builds.Made a quick set for my dad so he can use while travelling. 12 drivers - 2x SWFK 31736, 4x RAB32063, 2x 37AP015
Face plate is laser etched wood with laser cut shells.
Does seem like you need a lot more bass for BA drivers to match the feeling of bass produced by a dynamic driver.
The RAB seems to give me the same fits as well. I can never get a substantial extended high end shelf when pairing RAB32257 with SWFK, TWFK, or WBFK. It's like it just disappears. Strange phenomenon. I'm really jonesing for the new super tweeter from knowles. but the production ramp up is crazy slow and most suppliers are requiring 100 piece orders here in the states. Unless you are already purchasing direct. I can't buy 100 drivers just because Jerry Harvey made an IEM with the driver in what could only be a settlement of sorts from the Bellsing lawsuit that Knowles recently just won. haha. Anyone have experience with the RAU?Made a quick set for my dad so he can use while travelling. 12 drivers - 2x SWFK 31736, 4x RAB32063, 2x 37AP015
You can always reach out to Pro3dure Germany or Dreve Germany. Pro3dure is a little smaller manufacturer but their products are really well made. You might have more luck with them.I was out of the hobby for quite some while, but have components lying around to build another set. But I'm not sure if my lack 3 is enough.
Now that mcear is closed do you know of any sources in EU, that don't require having a business?
Can confirm pro3dure let me order from them without a business. Just send them an email, L-1 is what you want.I was out of the hobby for quite some while, but have components lying around to build another set. But I'm not sure if my lack 3 is enough.
there will be a slow creep up to your preferred frequency. Its all a matter of taste Vs that of calculation. Its also part of a passive network. Add one thing the drivers will respond one way. Add another or take away, more variation in performance will ensue. Of you are seeking to use it in a circuit, connect all drivers you are hoping to use. Then, connect that to your most commonly used audio source. Next, test FR of each driver followed by testing the impedance of driver. This is why so many in this forum utilize zobel networks. This will act to level the output of the drivers. In traditional audio speaker construction, one would use a zobel attached to subwoofer. More often than not, I will use them there as well. However, you can stabilize a tweeter response just the same. In order for the zobel to perform properly as an impedance equalization, you must calculate the parameters in circuit. If your values are not correct, there will be an electrical phase shift introduced that you will have to contend with.Quick question for those of you that have used the Sonion EST65. I am only wanting it to cover 5kHZ and up and my calculator says use 2.2UF.....anyone used these and verify the number? I see .47 used but that seems to allow 10Khz and up. Any other issues with these guys?
2.2µf it's good for EST, the bump at 2.5khz is difficult to remove even with 0.47Quick question for those of you that have used the Sonion EST65. I am only wanting it to cover 5kHZ and up and my calculator says use 2.2UF.....anyone used these and verify the number? I see .47 used but that seems to allow 10Khz and up. Any other issues with these guys?
Thanks...unfortunately I don't have an impedance rig. I'm proposing 2 ci's, 1 twfk, and the e65 per side...I'm drawing it out currently, but is a knockoff of piotrus-g's scary...I am apparently a bass-hog! As a cheap and dirty FR/Cap calculation, I use http://sim.okawa-denshi.jp/en/CRtool.php to calculate. I left the ohms of the EST65 at 1 as I understand it's gonna change as frequency changes....too simplistic?there will be a slow creep up to your preferred frequency. Its all a matter of taste Vs that of calculation. Its also part of a passive network. Add one thing the drivers will respond one way. Add another or take away, more variation in performance will ensue. Of you are seeking to use it in a circuit, connect all drivers you are hoping to use. Then, connect that to your most commonly used audio source. Next, test FR of each driver followed by testing the impedance of driver. This is why so many in this forum utilize zobel networks. This will act to level the output of the drivers. In traditional audio speaker construction, one would use a zobel attached to subwoofer. More often than not, I will use them there as well. However, you can stabilize a tweeter response just the same. In order for the zobel to perform properly as an impedance equalization, you must calculate the parameters in circuit. If your values are not correct, there will be an electrical phase shift introduced that you will have to contend with.
TwFKThanks...unfortunately I don't have an impedance rig. I'm proposing 2 ci's, 1 twfk, and the e65 per side...I'm drawing it out currently, but is a knockoff of piotrus-g's scary...I am apparently a bass-hog! As a cheap and dirty FR/Cap calculation, I use http://sim.okawa-denshi.jp/en/CRtool.php to calculate. I left the ohms of the EST65 at 1 as I understand it's gonna change as frequency changes....too simplistic?
oh, you can use the diy one laid out in the instruction manual for REW. Its not terribly difficult. You just want to be sure the reference resistor you choose is of high quality so your measurement will be as close as possible. Its what I have used for years.Thanks...unfortunately I don't have an impedance rig. I'm proposing 2 ci's, 1 twfk, and the e65 per side...I'm drawing it out currently, but is a knockoff of piotrus-g's scary...I am apparently a bass-hog! As a cheap and dirty FR/Cap calculation, I use http://sim.okawa-denshi.jp/en/CRtool.php to calculate. I left the ohms of the EST65 at 1 as I understand it's gonna change as frequency changes....too simplistic?
