And that speed would change with lift speeds I think, but would risk the chance of a failed print.
It does indeed, it gets slower, to account for both the extra torque required of the steppers and to avoid failing/separating. Some people have also done some interesting stuff with custom g-code to tilt/angle the bed on pull/separation to help with the surface tension, but its still required to be a longer process with larger cross-sectional area. I would expect that to be 100% correlated and unavoidable physical limit. It's just physics that all of them are starting to bump up against. I mean FDM ... its a tiny 200 micron plastic sausage, that we are trying to be precise with *** ... ha!! far from ideal, but my point is its a far cry fro what it used to be, since the stratasys patents all started to expire ...
also based on my experience with both msla and fdms, if you print a ton with xy and not much z, msla would beat fdms both in speed and resolution.
That makes sense. FDM printing at the moment is limited to about 60mm/s, or less. you can go faster of course, but most useful materials limit you to that or less
Hey i'm not a fanboi of any of them, whatever it takes to get the job done. I absolutely agree, that currently at least if acrylic is suited to your application, SLA without a doubt produces a higher resolution print. MSLA is just not workable in my space and most resins too weak for my usual purposes (not IEMs) and as mentioned I find the process tedious, wasteful and so messy, but we'll see, i'll probably end up with a small one of my own soon enough. I have only used other people's, so I cant claim
much experience there.
I will use my new FDM (qidi X-CF PRO) primarily more for enclosures, in combination with PCBs, printing moulds for vacuum moulding (chopped carbon) and CNC/laser cutting (I have neither at this point). I'm looking to get myself a small furnace for casting metals (from moulds printed directly on the FDM, when possible) and build an EDM cutter to round out the workshop (similar results to laser cutting, but able to cut thick material very cleanly including titanium, using your own fabricated cutting 'ends' for the electrode. CoVID has meant an explosion in Makers/ 'Micro-factories' and I just love making stuff
As you can see, I have other things I need to print, rather than standing around ...
the tubes, sure. I expect there is a work-around with dissolvable supports/IDEX. leave me with it
Also, i'll just leave you with this ... MSLA cannot and will probably never achieve full colour printing.
