saldsald
- Dec 9, 2016
Where did you get your resin from? I have tried several and none of them really worked out for me sadly. I have some nail polish remover alike that work quite well to remove the resin thou.Hey, I use the cheapest crystal clear uv resin I could find for tubing and it works like a charm. For everything that could touch my ear I'd rather use some medical grade stuff but since everything is inside the shell I have no problem with using simple uv resin.
The resin sticks nicely to metal and the tubes and I can always remove it with a scalpel/tweezers and some patience.
Got my uv glue from a friend, not sure on the details. And so far I'm just using universal plastic shells
I am trying to make a Y tubing with heat shrink and some 2mm ID tubes but they just don't stick together firmly enough by the glue. Guess I will need to buy more UV glue to experiment with then.
