Aldo40
Member of the Trade: Alambic-Ears
Some questions please.
On the 2389D the center tap , reduces the impedance ? If yes have anyone measure it ?
If I use a big resistor value will effect the sound quality ?
yes I already made measurements
Center Tape is a half-coil connection, so half the inductance and half the resistance.
the impedance is divided by 2 and the gain is a little higher than some db.
As we know, impedance increases with frequency. this is something to take into account
when choosing the transition frequency.
there are circuits that linearises impedances like zobel or lpad, on the configuration
proposed by Dhruv, a Lpad on a driver for example sufficed linearized
the impedance of a driver.
LPAD and Zobel are not compulsory circuits, there are severial methods.
then you have to deal with all these proposed solutions, but you can confide in Dhruv he has a very good experience in IEM
what do you call big resistance? a big value?
I don’t think you have to worry about that if you put a 2 ohms or 10 ohms does not affect the sound, the goal is to adjust it to the rest of your config, and maybe you won’t need it, you will see when designing if it is necessary
