i even use 470nF on some iemOne cap is enough I believe. One cap 2.2 uf is the lowest you can go and is the standard for the most tweeters .
10mm length i mean ,
Best is , the length of the tube to be as short as possible , depends of course the length of the nozzle .
2354 and 2389 are not tweeter. they are fullrange driver with emphasis on uppermidI have never tried it.
I don't know. For me 2.2 is the lowest .
I will try 1uf and below to a 2354. I will test it later with my ears .![]()
man, okThe 2389 is also a tweeter and that's for sure .
The 2389 is made as a tweeter.
The 2354 has also very good treble . See datasheet.
I never had and I don't have Wbfk or swfk.
low passWhat does series inductor does? Never used inductor but it seems that quite some big companies use them. And with inductor as rc low pass it does not add resistance.
I see! Since i have been seeing ue doing series inductor and series resistance, so I have been wondering that.low pass
but the Henry value is so low, i think its only for very minor fine-tuning and nothing else
i cannot consider it as a definite part of the crossover
they are still making them and its hiding somewhere in the dark corner inside the basement of sonion warehouseCan you currently get sonion E25 or E50 anywhere? Did they stop making them?
Edit: adding random thought: anyone used gutted TWS shells for wired projects? Lots of room in there for BA's...
its hard to get sonion 4100 , 4400 and E series
