mattmatt
- Feb 11, 2012
Thanks for always reminding us!OK, good to hear. Some of the guys from this threat got banned, for posting pro work, so I just wanted to warn you
Man......I have found a solution how to connect 4 tubes 1.5 mm each to a 4,7 mm nozzle
4,7 mm nozzle with 4 bores 2 mm each Bore I'm not posting the 3d design . I wanted only to share. Is this a pro work ? I don't want to get banned
A professional can give advice or tips if he wishes without being bannedI have found a solution how to connect 4 tubes 1.5 mm each to a 4,7 mm nozzle
The problem in multiple-driver designs is rather the place they take in the shell.I believe this is the biggest problem for most designers in the world using printers or not .
The diameter of each hole on the surface of the nozzle will effect the sound a lot .
Im talking about 4 driver design or 3 driver design
With independent tubes and same diameter from bottom to top without having a 10 mm nozzle
2.5mm tube on swfk32254 gives 3.5kHz resonanceThe problem in multiple-driver designs is rather the place they take in the shell.
In 3D design it is easy to integrate 4 holes see more , most designers is limited to 3-4 tubes see extreme cases of 5-6 tubes at spiral ears.
You have for example designs of 8 drivers on two tubes like the VE8, and it works terribly well so anything is possible
