Home-Made IEMs
May 25, 2020 at 2:31 AM Post #11,281 of 15,989
Has anyone ever built with these shells? I want to do a deep insertion build.
They're small so they can only fit a single BA. This one has brackets for either 29689 or 32257. It might be possible to fit other BAs with similar sizes onto the same bracket.
May 27, 2020 at 10:55 PM Post #11,286 of 15,989
May 28, 2020 at 1:44 AM Post #11,287 of 15,989
Hi guys,
I'm looking to do my first mod - Sony Mh750 MMCX mod.
i've bought a cheap soldering iron (https://www.lazada.sg/products/jvgo...ezers-uk-plug-i272457890-s423095948.html?mp=1) to get started and am looking at getting some helping hands (probably this https://www.lazada.sg/products/3rd-...o42.searchlist.list.3.6590487atntwrV&search=1).
I'm wondering what other tools/parts? flux? Is there any particular type of soldering wire I should use (thickness)?
You should use stranded, enameled wire. I just cut the wire from the detached cable.
May 28, 2020 at 5:01 AM Post #11,288 of 15,989
Yes buiyng a really cheap pair of earphones is one of the cheapest way to get stranded enamled wire. I can also recommend buying a syringe of the fake Amtech NC-559 flux. For the helping hands i would recommend blue tack, it was mentioned here a few post before. Its easier to use.
