Soundlink still sell them in china i think they send you some when you ask (and dont live in the us i think)Someone have a set of bellsing 10013 for sale OR know how to get Them?
Home-Made IEMs
- Thread starter Bilavideo
TOBIJampar
If you don't live in the US, contact SoundLink. They might be able to send them to you even if they are no longer listed in the Shop.Someone have a set of bellsing 10013 for sale OR know how to get Them?
Worked for me
Madmike1988
Thanks, in from Holland and contacted soundlink but they are out of stock they said!Soundlink still sell them in china i think they send you some when you ask (and dont live in the us i think)
Farquarl
- Jun 20, 2016
Hey,
Does any one know a good Tipp to get a few dB more at 3khz? Without changing drivers.
What's the driver combination? Looks pretty good.
dhruvmeena96
This iem ain't tip sensitive.Hey,
There is no peak to shift..
Farquarl
- Jun 20, 2016
HODVTEC, Bellsing Twfk, EDWhat's the driver combination? Looks pretty good.
They allread sound amazing tbh, but I think just a tad more at 3khz would be great.
What do you mean by "tip sensitive"?This iem ain't tip sensitive.
Can you change the damper or XO?
Can anyone suggest some good books on accoustics? Especially ones that could be applied to iems
Cheers
Cheers
GourmetEnte
dhruvmeena96
Your ED30761 looks like full covered. The vent looks closed offHey guys, I've been building the finale 2 IEM in a universal fit shell. When test hearing it sounds rather shouty. I was wondering if I'd have to adjust tube length due to the fact that I'm using a universal fit, cheers
This will cause the bass to die and make mids more prominent
Plus... There was no components in the iem... If I remember correctly.
GourmetEnte
The driver isn't fully closed off. However I don't know where the vent is when looking at the driver and schematics provided by Knowles. Is it on the back? If so then it shouldn't be an issue as it isn't covered.Your ED30761 looks like full covered. The vent looks closed off
If you're referring to the two resistors: those are two 1ohm resistors. The design calls for 1 2ohm resistor.Plus... There was no components in the iem... If I remember correctly.
Cheers
tomekk
dhruvmeena96
Yah.... This one I was talking about.Pads, if it's a mistake (I see two open pads), can cause asymmetrical peaks. You should also close the shell to compensate the chamber pressure.
Edit:
dhruvmeena96
Ohhh the minor compensator I called for.The driver isn't fully closed off. However I don't know where the vent is when looking at the driver and schematics provided by Knowles. Is it on the back? If so then it shouldn't be an issue as it isn't covered.
Cheers
The issue of shoutiness is due to covering of vent
