Is this a sla print or fdm looks very nice. I was thinking my self to get a printer. How did you scan the impressions ?Printed two new shells. With a two sound bores and a notch for cerumen. These are just prototypes they are not polished lacquered or anything else.
Home-Made IEMs
- Thread starter Bilavideo
Farquarl
- Jun 20, 2016
I got lucky and bought a scanner for scanning impressions at eBay. This is an sla print.Is this a sla print or fdm looks very nice. I was thinking my self to get a printer. How did you scan the impressions ?
Edit: Before i did that i scanned impressions using DAVID SLS with own hardware. Thats the only "cheap option" i can think of. But still sla printing the shells is quite an investment. You need a printer which is capable of printing biocompatable resin. These resins don´t have much photoinitiator in them so a LCD type printer won´t do. The resin itself is pretty expensive as well (350-40€/L).
You are really lucky the printers are no problem. but getting a good scanner. And another question from where did you get medical resin or is it non medical and you laquer it afterwards whit lack3 or somthing ?I got lucky and bought a scanner for scanning impressions at eBay. This is an sla print.
Farquarl
- Jun 20, 2016
Tbh i think the printers are a problem at least they are expensive as a 200€ LCD printer won´t cure the resin. I´m in contact with an audiogolist which orders this stuff for me. I will get Pro3dure resin in about a week. Someone wants a pair of monitors done and is paying for it. I´ll keep you posted if you are interestedt. I could also send you a small ammount of resin if you want to try it out.You are really lucky the printers are no problem. but getting a good scanner. And another question from where did you get medical resin or is it non medical and you laquer it afterwards whit lack3 or somthing ?
Wich printer are you using ?Tbh i think the printers are a problem at least they are expensive as a 200€ LCD printer won´t cure the resin. I´m in contact with an audiogolist which orders this stuff for me. I will get Pro3dure resin in about a week. Someone wants a pair of monitors done and is paying for it. I´ll keep you posted if you are interestedt. I could also send you a small ammount of resin if you want to try it out.
Farquarl
- Jun 20, 2016
Flashforge HunterWich printer are you using ?
Okay thats a expensive oneFlashforge Hunter
Any suggestions for something good sounding with CI, Hodvtec, RAB, SR and double TWFKs salvaged from Belsing 6 driver bundle?
kmmm
- Jan 25, 2017
is It possible to make masm7 with knowles drivers?...
MuZo2
- Nov 16, 2011
https://audiofool.reviews/building-a-custom-in-ear-monitor/
nice process described..
Can somone please explain me what the difference between.
Longer Tube vs shorter Tube
And
Bigger diameter vs bmaller diameter
Thanks
And
Thanks
et.haan
Longer tube, peaks shift left. Shorter, to the right.Can somone please explain me what the difference between.
And
Thanks
Bigger ID makes peaks flatter, raises the rest of the output to be louder. Smaller ID is peakier. Typically.
Farquarl
- Jun 20, 2016
Plus a small id tube with longer length acts as a lowpass.Longer tube, peaks shift left. Shorter, to the right.
Thank youLonger tube, peaks shift left. Shorter, to the right.
Madmike1988
Someone have a set of bellsing 10013 for sale OR know how to get Them?
Total: 16 (members: 0, guests: 16)
