Not without an Apple ID?It should work on windows too!?!
Home-Made IEMs
- Thread starter Bilavideo
MuZo2
- Nov 16, 2011
Hey everbody.....
here are some of my builds….mainly GK's and BS6's with zobel...….hope you like it......Nothing special though...
Great job, you seem to have advanced to professional level.
MuZo2
- Nov 16, 2011
It works without apple id for me.Not without an Apple ID?
mattmatt
- Feb 11, 2012
Have you tried the black one from them?Lak3 and the coloured Ones from pro3dure
emil2099
Guys, thanks again for helping on this thread. I have made my first BS6+Zobel CIEM and now working on MASM7 to fix some execution issues and hopefully improve the sound. Will write up some lessons learned once done (hopefully in a week).
Is there a common view on venting / Adel / Apex modules? I have noticed build up of ear pressure in my first CIEM which causes mild discomfort even at very low listening volumes. Has anyone come up with solution to this? Also is it right to think that any sort of venting will require an additional tube back to the shell or directly into Apex / Adel?
Someone know what went wrong here my first one was smooth but was to thick because i dip it 2 times in wax this one is bubbly but fits now
Can you see the bubbles in the negative? If I use old agar or agar that is too hot sometimes they come out like this.
I used the agar agar a second time i opend the bag 2 weeks agoCan you see the bubbles in the negative? If I use old agar or agar that is too hot sometimes they come out like this.
Did you ever try the pulver agar agar? I used the ready to go agar from mc ear
You can use agar a few times. However I think it really depends on how hot it becomes, how long it is hot and so on. I replace mine if it turns yellow.I used the agar agar a second time i opend the bag 2 weeks ago
Also you have to wait for the agar to cool down below 55°C so the wax does not melt when you pour the agar over the wax.
If you make a negative and wait for a few days the agar will dry and also create these kind of dimples.
emil2099
One thing I've learned is that I get better results starting with fresh agar agar which I got in powder form from Amazon but it is also readily available from supermarkets here in the UK really cheap.
Use 1 table spoon with 200ml of cold water, let it sit for 10 min, then bring to boil. I then sieve it through fine mesh to get rid of foam / bubbles and let it cool to 45 Celsius. Then make your negatives as per usual.
Might have been wax that melted a bit when poured over with hot agar. Might have been bubbles created by too hot agar. Carefully check agar temperature, I let it cool to ~50 celsium before pouring it and I get perfect results without any bubbles.
Hey.... could you send a link which Agar you exactly use???
Thanks Greg!
emil2099
https://www.amazon.co.uk/gp/product/B07YZPJKQF/Hey.... could you send a link which Agar you exactly use???
Thanks Greg!
https://www.mcear.de/epages/78599304.sf/de_DE/?ObjectID=2898047Hey.... could you send a link which Agar you exactly use???
Thanks Greg!
Total: 18 (members: 1, guests: 17)
