This could be totally wrong, and it is all in laymans terms, because I dont totally get this.
Anyways, I was thinking.... so Zobel makes no physical change to driver, only electrical. does the impedance of a driver really matter that much, enough to completely rework a drivers sound, and give it a massive soundstage/precise imaging? I was thinking, with dacs as nice as the Dragonfly and THX 789, there is no way that a zobel (if I understand what they do correctly) could make that much of a difference... I know BA is known for crazy inductance, something that is known to harm sound quality. Is this what it reduces? I dont see these amps have an issue with the resistance of a driver, just the inductance.... It makes sense to me, because I know inductance value is required for a zobel circuit.
I hear that with RAB it gives deep, rumbeling lows.... I thought this was largely impossible to change electrically, due to how the very fast speed of a BA gives it a "thin" sound. I know acoustic damping is acoustic/pnemuatic resistance, so it sound thicker and richer, due to a slower driver speed.... same thing with the highs. Does this mean that a Zobel can change the physical speed of a driver, like what could be seen on a waterfall plot?
Is there any reason not to use a Zobel... ever? If so, why isnt it incorporated into BA's, inside the housing? Does it have an application for the EST?
Also, in a circuit, where would I place it? I think, if I were to only use zobel, it would be like this (a few different applications)
MMCX/2pin > zobel > L-pad (only attatched to RC for that driver, dtec/cl/38xx/33xx) > RC filters > driver
MMCX/2pin > zobel > RC > drivers
MMCX/2pin > zobel > driver
or
MMCX/2pin > rc > zobel(s?) > driver
I think that the RC would always go after a L-pad so calculation can be made with less resistance, unless its required, for a low capacitance crossover?
Do you guys calculate crossover points with DC impedance?
I see on calculators I could do an L-pad, or use a single resistor (much higher value).... Is this how much resistance would go up?
Also, does etymotic have a zobel? On Rtings it has weird phase... Is this what a zobel does to phase?
