dhruvmeena96
QuestionJust finished a set of universals using the RAB 32257 design by dhruvmeena and Choy Wei De. I wanted to build something inexpensive to use with a Bluetooth adapter while at the gym or climbing. This is only the second set of universals I've built. Previous builds include three iterations of customs with Knowles GV, one universal with GV for my girlfriend, and a B6 + zobel ciem that I'm currently working on.
I think these sound great for a sub-$100 build. Bass reproduction is lacking a bit and treble could use a bit more taming to prevent fatigue. Overall, the quality for price is amazing and the work put into the zobel and tubing (dhruvmeena & Choy Wei De) for this is very impressive.
Following Choy Wei De's post for the tubing didn't take much time at all and I was able to finish it within 20 minutes. The zobel took a bit longer just because I was working with 0805 & 1206 size parts. I used uv solder mask to protect the joints and prevent shorts when compressed into the very small shell. The shell I used was perfect for this build, which is nice because I couldn't fit anything larger into them.
I think they turned out pretty nice and I'll definitely feel more comfortable using them at the gym than my customs.
What is that blue thing after zobel(in series to driver). If it is a resistor, please remove it. Any resistor will go in between zobel and mmcx(not in between driver and Zobel)
Suggestion
Use brown damper, white is for treble head.
Compliment
Best color scheme(blue foam tips) with blue shell. It looks sexy AF. And also blue gloves....
