dhruvmeena96
Absolutely. If you can fit the tubes through, everything will be fine. If you have two distinct holes it is a bit easier to get a nice looking finish, but functionality wise you can use one oval bore and fit both tubes. You will fill up the ear canal with resin anyways.
See my pics above on how to cover the outside with resin, that way you will also cover any remaining gaps. Sometimes when filling up the ear canal the resin does not fill all gaps between the tubes.
Get a 5mm ID tube, stretch it bit and fit these two 2mm ID(3mm OD) tubes.I will try this and report back. Thanks for your advice!
Btw, can the two hole drilled in the shell for the tubes be connected (top circles)? Or do they have to be distinct circles and separated (bottom circles)?
Extend the 5mm ID by a bit(2mm length extension from the two tubes to the end of CIEM nozzle end)
