Senor CIEM
- Mar 8, 2017
Beautiful!Just finished another build. Took me really long to fit the tubes in a really small ear canal.
Used 1.5 ID and 2.5 OD. 2mm ID would't work for this. Diameter of the ear canal is around 2.5mm.
Finished version:
I have the same problem with narrow ear canals, tried to do the scary build a couple of times and couldn't get the two 2mm ID tubes to fit my shells, the only way to make it work was to pour the acrylic with the tubes already in place.
I will try to send a picture of some tips that would solve your issue on sealing. They are some tips that come with some Westone IEMs.
Kind of yes and kind of no.Isn't the FED30048 out of production though?
It was from start...out of production.Isn't the FED30048 out of production though?
I will post some when I build the next pair. But it will take some time, maybe a week or two.
Knowles makes it as per order.
Some time mouser stocks it up(every year)
I had these drivers lying as I used it in hearing aids
For 25 drivers with a rate of 20$(cheaper than mouser)
https://www.digikey.com/product-detail/en/knowles/FED-30048-I04/FED-30048-I04-ND/4030036
2weeks wait time on digikey compared to 4weeks in mouser
You were counting...Well 25 is a lot. Anyone in for a group order? Also can you make like a dhruvmeena96 wiki or somehing all the information you drop here is so great but sometimes a bit hard to follow or find again when you need it. By the time i finished my MASM build you already made 40 improvements
