This is the exact formula, but you had a rule of thumb if we do not know voice coil inductance, which we don’t for knowles GV. We only have impedance.
Home-Made IEMs
- Thread starter Bilavideo
Ivan TT
HODVTEC's one is known (7.9mH), assuming same value for TWFK (or each driver) 0.47-1uF is a good starting point.This is the exact formula, but you had a rule of thumb if we do not know voice coil inductance, which we don’t for knowles GV. We only have impedance.
But I would try going higher (4.7-10uF) as higher capacitance seem to improve bass and provides less colouration (especially if resistor value is overshot by another 20-25%).
I don't really believe zobel for BAs should be based on formula (unless it's a starting point), tuning by the ear and alternatively using LIMP (although I did not like the straightest impedance curve I could get by adjusting resistance/capacitance) give better results.
PS: sorry, I don't have GV and will be getting it at some stage, but not too soon.
Sorry if I went a little overboard, I got a wrong impression that @dhruvmeena96 didn't understand such a basic thing.Please, I think the point is made sufficiently clear, we are all not professionals and we are all trying to learn.
IMO such things are negligible for our projectsWires do have a resistance, signals do take time to travel through a wire, wire loops do create an inductance.
Ivan TT
I did just that using mmcx connector and actually would not recommend it: too easy to overheat socket and too tricky to get it tidy.And this is how I would solder it for 2-pin
Best approach that works for me now is to solder 0805 SMDs together, seal with Bondic, solder to estron wires some place between socket and drivers, seal solder points with Bondic again, glue up to the shell. Going to try same approach on crossovers soon, have few well overdue multi-driver configurations to build
Thank you so much. I know from what you have told that we need to tune by ear. But having a reasonable starting point helps a lot for experimenting.HODVTEC's one is known (7.9mH), assuming same value for TWFK (or each driver) 0.47-1uF is a good starting point.
So you would chose the resistor to be the impedance @500Hz (wich is 50 Ohms) and the cap to be 4.7uF-10uF as a start value for experimenting ?
Regarding wire inductance/resistance:
I do think so too. But remember, we are on an audiophile forum, think about that next time you de magnetize your CDs.IMO such things are negligible for our projects
We are on an audiophile forum, that's why I burn-in my litz wires for at least 300hours before I build anything
/s
Ivan TT
Anywhere between 50 and 64 Ohm as a starting point, yes.So you would chose the resistor to be the impedance @500Hz (wich is 50 Ohms) and the cap to be 4.7uF-10uF as a start value for experimenting ?
Cap - 1uF as per hypothesized inductance of GV, but would also be planning to overshoot it up to 10uF.
I feel a bit bad about not having GVs to do the tuning on them similar to BS6's (but I have an excuse - it was either GVs or taking kids to Billie Eilish, the choice was rather obvious), but a friendly awesome head-fi'er may loan me a pair of GVs soon - stay tuned
dhruvmeena96
The important part is to get phase linear, the impedance to be flatten enough that it doesnt have unwanted peak and rising inductance impedance in trebleHODVTEC's one is known (7.9mH), assuming same value for TWFK (or each driver) 0.47-1uF is a good starting point.
Choy Wei De
- May 16, 2017
Possible to come with a middle ground there the Zobel value that works for both RAB and GQ?
dhruvmeena96
Wire have negligible resistance, well... Well, linear electrical phase takes care of timing issues pretty much on single driver setups.Please, I think the point is made sufficiently clear, we are all not professionals and we are all trying to learn. Wires do have a resistance, signals do take time to travel through a wire, wire loops do create an inductance.
But we are among audiophiles here, we should trust our ears.
Does anyone remember how @Ivan TT would calculate the Zobel for a Knowles GV? He had a nice formula for starting values.
On multi driver, if acoustic phase is corrected, then everything would sound on time.
Well you shouldn't expect source perfect time.
Plus, I don't remember the exact software, I think rockbox also had a feature for correcting time
Well media player classic has reclock addon(which doesnt work with win10 now)
You have to buffer music into RAM and then according to wire resistance average, you have to reclock the signal speed to get source perfect sound.
Because wires and cable have a law of diminishing result
OFC vs OCC copper has difference of 2% in overall signal improvement(which is neglibile)
So wire resistance, and signal resistance is a topic where we won't go to a positive end
Inductance and capacitance are unmeasurably low on common wire..
If it is bad wire(very bad) then you have to think about it
dhruvmeena96
No need, RAB near flat impedance when paralleled with GQ, gives more of a linear looking impedancePossible to come with a middle ground there the Zobel value that works for both RAB and GQ?
ForceMajeure
- Jan 19, 2014
How does Billie Eilish sound on your iems though
Ivan TT
Sounds quite good, actually - especially on BS6, to goosebumps level.How does Billie Eilish sound on your iems though
And blessedly no screaming teenagers (my SPL meter measured about 107dB level during the gig, BETWEEN songs).
dhruvmeena96
Based on formula is for single driver or a setup of same drivers.HODVTEC's one is known (7.9mH), assuming same value for TWFK (or each driver) 0.47-1uF is a good starting point.
Multi driver I hard to predict and I agree with @Ivan TT .
LIMP and ears are more important
Total: 15 (members: 0, guests: 15)
