@dhruvmeena96
Tried L- and T-pads today and they seem to work. Kinda. (probably because the values are not exact)
There is some sub loss but less than with just a resistor. General signature and dynamics of the driver are preserved, which is nice.
I'm currently experimenting with IR and RC low-pass filters.
IR seem a bit unpredictable/messy because inductors have notable resistance (14Ohms for 1mH) which needs to be accounted for.
But it could be an advantage because you can combine L-pad with 2nd order low-pass or T-pad with 3rd order low-pass in some configurations.
don't use inductor until or unless you are not making a series notch filter for your driver. and inductor has to be SMD air coil
series notch filter is for fixing the EMF(Electro-motive force) resonance which creates peak in Impedance graph and phase shift at specific frequency response response
the only driver which you can work on is RAF, ED and CI(Impedance graph available)
crossover is good in RC and is better after you make the reactive load purely resistive instead impeding.
If you use coil, it will become hard to control some factors.
and it is good if you know Theile small parameters of the BA before using inductor so that you can track the change in 2nd order harmonic due to inductor.
well let me explain
When we do a low pass
(RC crossover)
Resistor in series and capacitor in parallel
we add Voice coil resistance due to series resistance and also increase Moving Mass of BA(But the mass of diaphragm is fixed, right.....actually it is fixed, from what i mean to say, you slow down your driver for lower freq)
When we do a High pass
(RC crossover)
Capacitor in series and resistor in parallel
we first reduce the mechanical damping or electrical damping by parallel resistor, you can take it in any way(Electrical damping it is, but it is simple to calculate while taking value of mechanical damping). This make the driver have the ability to move faster and louder but can distort due to over excursion. then adding capacitor technically reduce the movement zone, which lead the driver to play loud on HF. You can say, adding capacitor in series reduce moving mass of diaphragm and resistance reduce mechanical damping
But when you do an inductor crossover
Things change as now you are controlling compliance ( compliance = z* 1/stiffness , where z is a constant of suspension).
This means you are controlling the voice coil directly instead of frequency as RC type does.
Here you can control the level of slope with more freedom and more precisely, but it changes the driver itself, which is okay on loudspeaker because they are loud, bigger and inefficient compared to super sensitive BA.
The bigger nature of loudspeaker prevents a drastic change in sound and voice coil of a loudspeaker have a low inductance compared to 7.8mH on RAF driver with 22ohm impedance vs Mark audio alpair7 21.30uH and 5.48ohms.
plus loudspeaker do need inductor to actually show some real change in sound profile while crossover by desire of ours.
BA higher impedance also means the EMF(Motive force) and resonance lies higher in 2kHz compared to dynamic driver low frequency resonance and a very high rise in treble impedance. Higher inductance of BA show variability of BA in phase nature and inductor crossover can do some changes which might not be good
untill or unless knowles dont release Qts, Qms, Qes and other parameter, dont try using inductor
well you can, but then you have to calculate and derive the things properly too(I can help for some drivers though and can give some formula)
plus one more thing.....SMD small core inductor may be tempting but never buy for BA purpose becasue that small inductor core may saturate, again showing some bad behavior in impedance. always get an aircoil and also tape your BA with MU metal tape(dont plug tape or vents and nozzle, only body)
Note:
well RC crossover can be parallel or series to any value here according to calculation in depth for perfect crossover but you can only see two inductor
1. Impedance
2. Springiness of coil or stick in BA(Compliance in parallel)
Impedance is okay
springiness needs to be stiffer and joining a series notch filter to Driver may load an inductor parallel to compliance, which may reduce the resonant frequency and rising impedance
but the cap and resistor are also that much important
One more thing, the ideal crossover cross is smooth and symmetrical but that doesn't really happen because the crossover component doesn't work as intended
Reason
1. We seriously don't know driver is working properly(Q factors and thiele parameters)
2. SMD component has more error than rated
3. Bigger component have more tolerance and less deviation
to be continued.....................
More complex part ahead
to cover:
how a capacitor, Resistor and Inductor affects the signal in line.
Impulse response
Burst Decay
CSD
Harmonics
Resonator and Formula's(I still dont get the FIBAE BLACK, so dont expect you will make a FIBAE BLACK)
I’m having good luck using a base plate of prefabulated amulite.
well.....hmmm i didnt get the joke
prefabulated amulite is fictional thing ryt(I know i destroyed/ruined the joke, but still the reference is out of my comprehension)
What lol
@piotrus-g
well why FIBAE 1 is my favourite till now
He got the custom driver according to his spec and he horned it to make a limited band a wide band
plus BA are fullranger due to resonance at 2kHz to 3kHz and if you remove the resonance for perfect phase and linear impedance will lead to true nature
(BA are limited by nature, sealed box so small can create the impedance so high in mids compared to dynamic resonance in bass)
Dynamics are real full range because it has been perfected over the period(DITA Fealty and truth, Hifiman RE2000) or this
DIY driver
The driver i linked is legendary for diy purpose and even outclass DITA or Senn IE800s driver in everything
and it is true 48kHz extension with <1.4us impulse response. Faster than any BA which are <1.6 for SWFK(Fastest)
Note:
BA with flat impedance are faster. Again FIBAE 1 as example
BA were introduced very late according history but are technically faster for smaller voice coil movement and diaphragm. But iss
