Home-Made IEMs
Feb 15, 2017 at 4:53 AM Post #5,986 of 16,343
The CI30120 seems much less peaky than the CI22955.
Feb 15, 2017 at 5:00 AM Post #5,987 of 16,343
Very much appreciated! Thank you for doing this. May I ask what iem is it from?
Also I know you probably soldered the pads correctly, but I found out that if the CI pads are not soldered covering the hole they got under, they act kinda similarly to the FR you posted.
Feb 15, 2017 at 6:37 AM Post #5,988 of 16,343
It's from very popular 10BA Chinese Hong Kong company Flagship ;)
Do you mean the red or green plot? If you don't cover coil pads fully you essentially create a venting, but I think this wasn't the case here.
Feb 15, 2017 at 7:39 AM Post #5,990 of 16,343
  It's from very popular 10BA Chinese company Flagship ;)
Would you provide your comments on the sound of the unnamed flagship? :P
Feb 15, 2017 at 7:59 AM Post #5,991 of 16,343
I can for universal fit version cause I haven't listened to the custom unit. They use slightly different drivers and different filtering. from memory they were pretty rich, full bodied sounding IEMs, good extension on both ends. It's like a W shaped signature, overall it's ok sounding IEM if you like thick notes but at the same time some edge on higher frequencies.
Feb 15, 2017 at 8:22 AM Post #5,992 of 16,343
Different drivers for universals and customs? That's the first one I've heard like this :O
Thanks for your impressions though!
Feb 15, 2017 at 12:45 PM Post #5,995 of 16,343
I had an interesting experience when testing my new IEMs. I made them with the new UE style connectors. I first tested them using my original UERM cable and then I tried them with a mic cable I bought off Lunarcables. Last I tested them with a copper upgrade cable.
Assuming the copper cable is the normal frequency response, the UE cable resulted in a 2db frequency response dip from 3kHz up to 6db dip at 6kHz. The mic cable also resulted in a dip but was half that of the UE cable.
Listening tests afterwards also proves the testing correct.
Anyone else experienced this?
Did you volume match?
Feb 15, 2017 at 1:42 PM Post #5,996 of 16,343
Yes - my sound card for testing this has no volume control :P I think it is due to the cable resistance is slightly larger
Feb 15, 2017 at 8:01 PM Post #6,000 of 16,343
I see what you mean. Unfortunately I can't volume match them. The sound card was made purely for measurement purposes and doesn't have a volume control. Though through listening tests I can confirm that the sound gets much worse no matter what volume I put it at.
  • Back
