JorgePantalones
- Sep 24, 2016
Hi. Myself experience failure making shells. They cure very uneven. Some parts solid while some parts on the thicker walls of negtive dont cure at all, probably due to the silicone negative i went over to use. Before i used gelatin/kanten and larger forms/cups to mold the negatives in. Now i bought the small size cylinders, i probably should have bought the big ones. What size do you use?
I don't know that the size of the cups will matter as much as balancing the depth of the mold you pour with the width of the cup:
I've been curing mine on a turntable with the majority of light coming from the bottom of the mold up. My first two tries had a hole in the indentation between the bit that sticks into the "triangular fossa" and the part that dives down into the ear canal. I couldn't seem to get enough light in there until I lowered the volume of the mold 5mm (1/4") and then everything came out great.
As a bonus, in my case, the lowered depth of the mold made the bottom of the cast (end of the ear canal) shallower than the sides. This cured the ear canal a little thicker and deeper which has been better for seating the speaker tubes.
