Home-Made IEMs
Sep 17, 2016 at 10:44 PM Post #5,281 of 16,034
  Thanks - but does it look "metallic" like in this photo? http://i58.tinypic.com/255o12c.jpg
I know it is really silly to get one specific type of cable - but I've always thought that it looked amazing.
If you are willing to pay the price, then go for estron wires, that's what you are looking for.
https://www.aliexpress.com/store/product/0-4-mm-Tinned-Copper-Silver-Plated-Wire-Hearing-Aid-Accessories-Connector-Music-Earphone-Receiver-Connecting/830007_32401299542.html
Sep 19, 2016 at 2:13 PM Post #5,283 of 16,034
anyone can help soldering four wire cable to 2.5mm four pole jack for cayin n5 balanced? I just need to figure what cable goes where? I have occ silver plated four wire cable with 3.5 3 pole
Sep 20, 2016 at 4:54 PM Post #5,284 of 16,034
http://www.ebay.com/itm/Astron-XL3-Dental-Lab-Curing-Oven-for-Light-Cure-Material-Polymerization-/361735375925?hash=item54391bcc35:g:lpgAAOSw5ClXxHcV
Anyone know if this is a sealed chamber thereby doing away with the sticky inhibition layer?
Sep 20, 2016 at 5:02 PM Post #5,285 of 16,034
From the pictures it does not look like a sealed chamber.
May I ask what the sticky inhibition layer is?
Sep 20, 2016 at 6:16 PM Post #5,287 of 16,034
  When you cure UV acrylic in open air, you get a greasy/sticky "inhibition" layer.  Some professional uv ovens like the Dreve unit a few posts up, remove oxygen so you don't get that.
I think there may be a misconception about how "removing oxygen" actually works.
To remove oxygen you need unit like Dreves Polylux 1000N or Eggers EL1+N - the "N" stands for Nitrous. Those units operate by injecting N into the curing chamber, replacing Oxygen as oxygen is responsible for inhibitation layer.
It's nowhere near what can be considered as DIY equipment. You need a licenced professional (at least in Europe) to connect the gas bottle to the curing unit. N bottles are 1. hugh and heavy 2. very very expensive. 3. could be deadly when mishandled.
Post curring solutions from Dreve/Egger will give you perfect results just as if the shell was curred in N atmosphere.
It's not worth risk or cost for small projects.
Sep 20, 2016 at 7:55 PM Post #5,288 of 16,034
Also most dental polymerization chambers/ovens only direct uv light downwards, also with limited reflective interiors as most dental procedures will need solid polymerization or single layer polymerization. Not hollow meaning they do not us a uv blocking plate. Just food for thought, I too looked into dental cure units.
Sep 22, 2016 at 6:09 AM Post #5,295 of 16,034
Knowles ED29689
1500Ω damper
20Ω resistor in series
2mm/3mm tubing length
Knowles ED30761
2200Ω damper
1.5mm/5.5mm tubing length
...could be wrong though.
I can't find any spec sheets for that ED30761 though.
The ED29689 does look kinda "bad" though. But I guess it is being used as woofer here so perhaps the region the datasheet don't show is good.
