switch polarity on either DTEC or CI - you're clearly canceling both out.
Home-Made IEMs
- Thread starter Bilavideo
bhazard
- Jul 15, 2013
Subbed. I made my speakers via a DIY kit and some custom work, and I'd love to make a custom IEM in the same manner.
Since there is no OP with a summary of info, what's the best starting point for me to learn crossover assembly, favorite designs/parts, etc?
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Start reading backwards
For those who don't know, here is a Japanese blog with a list of drivers used by in various CIEMs
http://84audio.blog27.fc2.com/
https://docs.google.com/spreadsheets/d/1jguxmYfEmZdHEGIUDvQUnfm3vhxo51WeNKKG0_oRtMA/pubhtml
It gets updated regularly, though it doesn't have Xovers info, it's a great source
ForceMajeure
- Jan 19, 2014
Coil is right, try to go backward, there is a googledocs made by Furco at some point collecting various posts which explains all the basics.
https://docs.google.com/document/d/1jU37oWefx2dGS8dWw5TVkugEtwJh_bh3fuUBNe2HrQg/edit?pref=2&pli=1
There is a also a subreddit much younger than this thread (with much less info and less to go through) that gather information on CIEMs. https://www.reddit.com/r/DIEMs
It is a long thread to go through, I did when it was about 240 posts already, took me 2 weeks but was worth it. If you already know crossover electronics from speakers design then it will be easier for you to grasp the concept.
Here is a Sonion (Sonion is a brand, manufacturer of balanced armature drivers) brochure explaining the basics
http://www.sonion.com/~/media/Files/Academy/Academy_ProAudio__DocCode_304_V_001_Web.ashx
Sonion and Knowles are dominating the market of BAs, among the many drivers they have, some are quite similar (with almost the same frequency response and impedance).
Sony lately started to produce their own BAs mainly for their latest products.I think they are also used by Klipsch in their latest IEM lineup but cannot be bought individually. Other manufacturer are based in China and Japan (more info here).
You could try to open the QT5, I am sure you could learn a lot about designing IEMs and also share with us diyers the secret sauce.
Pete64
- Apr 30, 2016
So finally i got CI-22955 with 10 Ohm in 22 mm 1,5 mm ID , and ED-29689 with 2,2uf and white damper with the suggested horn in a 12 mm long tube. Tha sound is nice in bass, quite driven and punchy. Mids are really good imho, but heights still a little low, and not at all "shimmering". Would it need another driver to get better heights? What does half coil and reversing polarity do for a difference?
Tjgonzo
- May 20, 2016
Do they require you to buy the connectors?? I have about 200 female mmcx connectors and wouldn't need them.
Hey Shilohsjustice, I can't seem to get my hydrocolloid to liquify without bubbles...Any other tips? I have been heating on stove.
Also, how would you suggest I make a white faceplate? I have transparent Fotoplast at the moment.
raptor18
- Aug 21, 2004
Driving high frequencies is very difficult due to the nature of BA's (and speakers in general) where the impedance raises a lot compared to the rest of the register. The higher the frequency the higher the impedance which makes it more difficult to drive*.
That is why you want to have a BA with relatively low impedance so you can lower the high frequency impedance to reasonable level.
It is described in this article (graph 2)
http://www.knowles.com/eng/premiumsound/Resource-center/The-Science-of-Premium-Sound-Using-Miniature-Transducers
Running the ED-29689 half coil lowers the impedance by half, so you will have more reasonable high frequency impedance to be able to drive the high freqs.
However, when doing so, you will drive a very low impedance BA which can be bad for your damping factor and even your player which needs to output a lot of current.
That is why you need to create a crossover quiet high so you don't "play" the lower areas where the impedance is low.
*Higher impedance isn't harder to drive, it just creates a big difference between the high freqs and the rest of the frequency band which has a lower impedance and will play louder than the high freqs.
Pete64
- Apr 30, 2016
raptor18, thank you for a very explaining answer! But how is half coil and reverse coupling affecting output and frequenzy?
dustdevil
- Jan 10, 2012
Tip of the day: Have good ventilation when working with uv resin (and probably other types of resins) as long term exposure to its vapor can cause illness
CoiL
Most resins react and "exhale" toxic compounds, cyanide included. I have worked/studied some resins and worked with them while working with carbon/glass-fiber molding and these reactions should be carried out ONLY in ventilated room/chamber!
Squirg
- Jan 7, 2016
Pete, I was up most of the night working on this. I'm stubborn and determined to use the DTEC. I had probs with CI and DTEC cancelling other out and switching polarity helped this out a lot! (Thanks Piotrus!!!) In fact, I think switching polarity on CI and ED helped too. But, the real fireworks happened when I did away with resistors on CI and DTEC and ran them wide open and put a resistor on the ED. WOW! What a difference! I got CI and DTEC to play nice but every time I hooked up ED, the sound turned to crap. After I incorporated a 10 ohm resistor to ED at half coil, it mellowed it out and harmony and bliss filled my ear holes. Half coil bumps SPL by a few dbl, maybe 6? You do not need another driver, ED to my ears gets way up there! Happy tuning!
Pete64
- Apr 30, 2016
Wow, that sounds great! Good work there! Could you post a schematic with what you finally did?
Squirg
- Jan 7, 2016
Not sure if this works or not:
https://docs.google.com/drawings/d/12XHs-AufgU2IE7Yzq-O08dijiVQDOBchOBTqqkaIfQw/edit
Let me know if that works!
Thanks
Thanks
Great to hear it. My thoughts are that you were still cancelling ED, if you got a "crap" sound but none the less. It would be great idea if you could post schematics of your design I could check it out in spare moment and let you know if there's something you could do better with implementing ED.
If you decided to post graphs, please post one after your new solution and before so that we can see what exactly you'd changed.
EDIT: Oh I see you posted a schematics, but more details would be nice - right now I cannot tell polarity of the drivers. - You can mark either spout or coding (numbers) side so that we can see what position your drivers are.
Squirg
- Jan 7, 2016
Sorry, I realized my DTEC was wrong. This should be more accurate...
I really can't give a graph of before because I tried wiring it any way possible before coming to this. Thank again, Piotrus! Us newbies are very fortunate to have you around!
Total: 24 (members: 0, guests: 24)
