Shilohsjustice
- Nov 28, 2014
Do they require you to buy the connectors?? I have about 200 female mmcx connectors and wouldn't need them.
No they dont require those, i just thought you might need them as well, you can get just the pack of cables alone.
What type paper/transparency paper are you using for your toner transfers?
Originally Posted by CoiL /img/forum/go_quote.gif
Actually I`m getting interested in trying to make one DD+2BA woodie - any recommendations what drivers combination to use for beginner in DD+2BA setups?
Thanks raptor18, i will try horn and see what it will do. Anyone used the detec-31116?
Thank you Squirg! I did'nt find any info about 31116 either, maybe i'll try Knowles directly? I sure will try that horn idea too. Now im in progress making new impressions and shells as i rebuilt the ones i now have five times ) and not careful enough broke one ci and one ed. Is there a tread somewere i missed with "recipies" for different (but good ones) signatures? like Westone copies or something like that?
