MuZo2
- Nov 16, 2011
good info. But does it dissolve in uv material like egger? what about food color?
I have a suspicion that some CIEM makers, when doing shells with intricate patterns like the above swirls, etc., may perhaps be skipping the usual 'wax-dip' stage when they are processing the ear impressions.
My suspicion is that they create the patterned acrylic CIEM shell, as a true 1:1 to the client's un-dipped ear impression, and then dip the created CIEM shell in clear UV acrylic, afterwards, to give it a very shiny, vivid, lustrous appearance, and yield approximately the same increase in overall shell exterior volume as would ordinarily be the case when using the usual 'wax-dip' stage during impressions processing.
That's not something that would work if you ask me.
Can you please elaborate, why it wont work?
1. You cannot easily control thickness during such procedure
2. Uncured material would leave "spots" in places where shell would be more sleek and repel uncured material
3. what about inside of the shell? dipping would result in flowing of material into hollow shell.
4. Shiny shell is a result of fine polishing and correct lacquering procedure.
All CIEM lab tour videos i've seen online, i haven't seen anyone showing the lacquering process. Are they just not showing the process or do some CIEM producers really not lacquer the shells?
Just as a precaution, before this topic turns into an avalanche, let me reiterate that I'm not stating that an outer transparent layer is an absolute, confirmed fact.
Nor am I stating that I feel it is standard practice.
I am very well aware that it is generally not done at all - the numerous videos I posted here make that very obvious.
All I am saying is that I have a suspicion that some complex shell decorations appear - to my eyes, to have a thin, outermost, layer of transparent acrylic. Perhaps I am wrong about this (it is possible that they are just highly-polished), but until I definitely know otherwise, I will continue to suspect it
OK, fair enough, but how do you feel the lacquering is accomplished, then?
Actually wax procedure also leaves uneven thickness.
I have seen lacquer applied with brush evenly only on outsides.
I'm sorry for sparking such enthusiastic conversation around coloring and finishing of shells!
Something along the lines of:
