vector1
- May 28, 2014
Are you measuring it on open shell or bare drivers? I measured HODVTEC yesterday and while bare driver measured quite poorly it improved dramatically when I put my fingers near the vents almost closing them, bass improved and response was really good.
It's because HODVTEC having 4 quite large vents makes it seem as if the sound was leaking out.
It was open shell, considering only the front of the driver is embedded in the boot that I printed for testing. I'll certainly try blocking the vents tonight with some pieces of tape to see if that helps.
Also, the HODVTEC wiring diagram is quite confusing until I realized that the drivers were connected in parallel not series... Couldn't decide which side to solder on until I put some thought into it.
I'd love to test out sonion drivers, but I certainly can't afford to buy a tray of 25 at once... HODVTEC should do for now!
Xymordos
I can also hear that rolloff between 50-20Hz, which is why I ask. On the whole, having both CI and HODVTEC in the same shell might not do much for the overall sound. Maybe dual HODVTEC would be easier to configure than CI and HODVTEC, which are subtly different when I listen to then individually. I prefer HODVTEC at the moment though.
