Home-Made IEMs
Aug 4, 2014 at 1:45 PM Post #2,101 of 16,031
I...don't have enough knowledge to answer that question :p I feel like it's a good investment...
Aug 6, 2014 at 4:38 AM Post #2,102 of 16,031
Recently, after buffing down my quad IEM in an attempt to achieve better comfort, I though I had somehow managed to kill the DTEC driver because all the base disappeared. Turned out that I had removed just a few to many mm from the end of the tube and it totally changed the sound signature. I was able to resolve the problem by attaching a small bit of tubing to the end of the DTEC's sound port and the thump returned to my music.
Aug 6, 2014 at 10:00 AM Post #2,103 of 16,031
Just asking, but has anyone managed to reproduce a decent 20Hz sine wave on IEMs? For all my tuning, I can only get a relatively flat response to 50Hz, and then rolling off to about 25-30 Hz before I lose all response.
Aug 6, 2014 at 11:12 AM Post #2,104 of 16,031
Yes, but it depends on drivers - some drivers roll off some don't. Typically non-vented roll-off.
Aug 6, 2014 at 12:35 PM Post #2,107 of 16,031
HODVTEC has quite good sub bass! I feel that it sounds better than the CI! Not sure how to improve the roll off though. Usually I see 10-20db roll off from 50 to 20Hz?
Aug 6, 2014 at 1:20 PM Post #2,109 of 16,031
  Maybe my ears just aren't sensitive to 20Hz... I'm using a HODVTEC so I'd expect reasonable amounts of sub bass.
Are you measuring it on open shell or bare drivers? I measured HODVTEC yesterday and while bare driver measured quite poorly it improved dramatically when I put my fingers near the vents almost closing them, bass improved and response was really good.
It's because HODVTEC having 4 quite large vents makes it seem as if the sound was leaking out.
Aug 6, 2014 at 1:43 PM Post #2,110 of 16,031
The HODVTEC measured like CI even with the vents open for me o.O
How did you think they sounded? Was it CI or the HODVTEC for you, as a personal preference? :p
Aug 6, 2014 at 2:26 PM Post #2,111 of 16,031
I didn't listen to it but if I was to pick ultimate woofer it would be 38DJP007Mi/8a - this is one is unbeatable right now. From what I know no other woofer performs like this :)
