I tried blutak but it just wouldn't stick strongly enough. The tiny wires I have are quite stiff and can be quite a hassel to get them to solder properly. I usually have to end up covering all the joints with resin to prevent them from coming loose. The tubing affects the peaks of the driver quite greatly I found. Also a small difference in distance from driver to ear can cause massive phase changes
Thid is quite difficult to work with.
(My ED driver has nothing under 5k so I am sure that is faulty)
