mattmatt
- Feb 11, 2012
Good to know this! Thanks for correcting me! I think the LPF is a great idea. No idea why I did not think of that. Dumb dumb moments.6kHz peak is inherent to 33AJ007i/9, you won't get rid of it unless you go for different HF driver that would help offset this with thanks to slightly different phase (TWFK-30017 is recommended) or find such a clever crossover to cancel it out. Overall moving dampers won't do much here. If you need more 1kHz change the damper to orange. If you want to get rid of 6kHz by acoustic means - 2xyellow damper and smaller diameter tubing would do it, or low Hz low pass filter
