This link speaks briefly on it. Gives you the general details.
http://www.mother-of-tone.com/conversion.htm
Multibit is also R2R by the way.
1. Delta Sigma (good)
2. R2R Multibit (better)
3. R2R Ladder (best)
Delta Sigma (DS) has a single switch and lots of guessing done. It's in short, a single switch or 1-bit.
R2R Multibit is like what you see with old chips like the PCM1704, it has more switches implemented thus has the ability to decode multiple bits of information (multi-bit).
R2R Ladder has resistors to compensate the voltages instead of these switches thus is more accurate. The removal of the switch noises that can cause measurable ring improves further on sound quality.
No-OverSampling (NOS) removes the FIR filters and whatever else digital oversampling that's built into the hardware (oversampling chips), generally to smooth out the edged lines and improve SNR/THD measurements. The key concept about NOS is to remove all these filters to retain the original signal. It's a "purist" approach. Theoretically our ears already have natural filters built in since birth, so when hearing an original sample, you'll perceive it as sounding more realistic. It's not only a perception because it's in fact true. Analog should retain it's natural qualities. Also when a signal leaves the DAC, it already goes through certain filters of it's own. No need for abundance. The idea is that too much filtering will just lead to digital glare. By removing all this, the NOS sound becomes more like vinyl (likelife). Music no longer sounds forced. The con however of removing these filters is that the measurements of the DAC doesn't run as high. People assume the best DAC's have the best numbers and that's certainly untrue. Brands fight for numbers because they know it's a selling point thus implement the use of more delta sigma chips to lower THD and increase SNR. While the use of more chips does improve sound quality by a small margin, there's a limit cap to how better it gets. Generally by switching from a delta sigma DAC to a delta sigma DAC, you might be getting a more different sonic signature than an actual improvement. Perhaps the improvement is that you like it more, so there's that...
