potterma
- May 5, 2013
Holo specs have not been independently confirmed as far as I know. If you believe the manufacturer (I never do) the noise floor is below -125dB which is fine and indicates resolution in bits is limited below 21bits. Anyone got an oscilloscope and a Holo?
You realize that 125 dB down on a 5 VRMS signal is 4 µV PEAK, right? Good luck seeing that on an oscilloscope. Even the $17,000 Lecroy High Resolution Oscilloscope is only 12 bit...
