- Apr 16, 2013
I can plug a USB connector in snugly, but the socket itself, internally, is loose.Loose in what way? Does the whole port wiggle or does your USB cable slide back and forth?
Mine has quite a bit of play at the connector but I can't tell whether it is moving internally. Initially I was concerned about this but it doesn' seem to be causing any problems with playback.I can plug a USB connector in snugly, but the socket itself, internally, is loose.
Yeah, I don't think I've experienced any physical disconnections yet from it. It's the one shoddy thing about the build I've found.Mine has quite a bit of play at the connector but I can't tell whether it is moving internally. Initially I was concerned about this but it doesn' seem to be causing any problems with playback.
I have only ever used the i2S out to my Holo Spring 3 Dac with the Red as this has always been the best way to connect my Holo Dacs in the past.Thank you rocky500 for ansvering my questionWere you using the USB out to DAC and USB in from a drive at the same time?
First thing….setup was a breeze. I didn’t have any issues I’ve seen others talk about. Had 3 updates to go through and it was good to go. All set in under 10 minutes.So, what are your first impressions?
Great news. It's so nice to invest in a new device and be fulfilled by our expectations!! watch out for future upgradesFirst thing….setup was a breeze. I didn’t have any issues I’ve seen others talk about. Had 3 updates to go through and it was good to go. All set in under 10 minutes.
My connection: Ethernet in using as Roon bridge, Red-> May kte (Curious usb)-> Feliks Envy (BJC XLR) / Schiit Folkvangr (AQ rca)-> Susvara, Hd800s, Radiance, Clear OG mainly.
Definitely an upgrade in sound quality over coming usb from my laptop. Specifically… increased clarity and separation, blacker background. Not sure how best to describe it exactly but notes in general have more weight, sound is more impactful and dynamic. Early stages so far but that’s first thoughts.
So far, so good![]()
Did you try RopieeeXL? I couldn't get this to work but I need to try again using a different DAC, I believe there is an incompatibility issue with my Ayre QX-5 Twenty and the Red. It definitely hasn't been as smooth sailing with the Red and UPnP as I had hoped. Interestingly, just putting Raspberry Pi OS and mpd/upmpdcli on a card seems to work fine.I could only get one OS (Moode) to play music.
For myself, I was really looking for a stand alone player/streamer that could work with i2S.Did you try RopieeeXL? I couldn't get this to work but I need to try again using a different DAC, I believe there is an incompatibility issue with my Ayre QX-5 Twenty and the Red. It definitely hasn't been as smooth sailing with the Red and UPnP as I had hoped. Interestingly, just putting Raspberry Pi OS and mpd/upmpdcli on a card seems to work fine.
My impressions so far, from random listening/YouTube from my speakers, compared to no DDC:Specifically… increased clarity and separation, blacker background. Not sure how best to describe it
Yeah, I’m happy with it! Granted, I don’t have any experience with other like components to compare so I can’t speak to that. In my case though, the Red accomplished getting my laptop from being directly connected to my chain and it’s a pretty significant improvement.Great news. It's so nice to invest in a new device and be fulfilled by our expectations!! watch out for future upgrades
I think I'm going to crack soon. This is to replace my SOTM 200 neo streamer + sps-500 PSU + Singxer SU6.
I want to reduce my number of boxes, if possible to benefit from an improvement in sound and above all to be able to continue playing with HqPlayer NAA, Bubleupnp, Spotify for the family,...
Also glad to finally have something because I’ve been researching and debating what direction to go for source/server/player for well over a year. All the SGC, Rendu, Innuous, Antipodes…it’s kinda overwhelming.! Especially with SGC and all the filters/PSUs etc!!! Yikes
My goal is also to add HQP . Currently use Roon but not HQP. My thought is to get a SonicTransporter i7 next to handle Roon and HQP upscaling out to Red and be done! (Like that’s a thing!)
Any thoughts on components to run Roon/HQP (maxed) on?? TIA
Well, the ethernet is only an input. USB is input or output. SPDIF is only output. So depends on what setup/usage you want.I've heard its USB and SPDIF aren't as high quality as say its LAN connection but that could just be hearsay as well, so I'm planning to test both a networked setup and a straight to USB configuration to check for preferences/differences. So basically the outputs of the Red are solid in all regards
Just following as I do not yet own a Red, but with Ropieee if your specific hat isn't listed Just use the generic Hat, for any "Hats" I had using a RPI it was always that one if yours wasn't listed in the main selection...Hi,
I wanted to try other OS with the Red, to output over Spdif.
Moode 64 bits : unable to configure the hat (not showing up)
Moode 32 bits : the Holo Audio hat appears and is working fine
I'm stuck with Ropieee XL, which "hat" should I select to get it working over spdif please ?
List of available hats : https://ropieee.org/audio_hardware/
Thanks in advance
Stay updated on iFi audio at their sponsor profile on Head-Fi.
