Holo Audio Red Streamer
Apr 24, 2023 at 4:59 PM Post #826 of 2,584
Thank you for your input, nice to hear about the I²S connection working straight out the box. There is allways a time period to let things settle, I´m in the half way in burning in my DI20HE and R-27 2021 so the Red can get in the line:smiley: I´ll be using the USB out to DI20HE and I²S from there to R-27. Of course I have to test the connection straight to R-27 via I²S. It seems that my Red is at a place called Oirschot at this minute on route to Finland, hope to get my hands on it next week! Ordered from Magna.
I'll be interested to hear your observations comparing Red I²S out to your R-27 vs DI-20HE I²S out.
Apr 26, 2023 at 5:12 AM Post #829 of 2,584
I received my Holo Red two days ago. I already packed my Zen Stream... This is a great little unit. Well actually it's bigger than I thought and much heavier. Built like a tank, like many has said before. It also plays much nicer together with my Spring 3 when used as HQP NAA. With Red in place, HQP doesn't lose the DAC connection as easily as it did with Zen Stream. I had to carefully turn on the equipment in correct order to make the DAC visible for HQP when I used ZS. With Red, there's no such problems. Also it sounds great, small but noticeable improvement over ZS.
Apr 26, 2023 at 8:23 PM Post #831 of 2,584
Has anyone compared Red as a DDC against the usual top flight suspects like Denafrips Gaia/Hermes, Berkeley Alpha USB, AudioGD DI-20, etc?
I'm still waiting for my Red to ship, and I bought it solely to use as a DDC. I have a Gaia, so I'll be able to compare soon, but while I wait, just thought I'd ask.
Apr 26, 2023 at 9:59 PM Post #832 of 2,584
Hi,
I got the Holo Red streamer and want to use it with the May DAC. I have connected the Red to the ethernet and the May Dac to the USB out of red. I want to use HQPlayer NAA. Below is my setting. I installed the windows Holo driver from here - https://www.kitsunehifi.com/holoaud...re-2020-same-firmwares-from-4-67-driver-pack/.
In Hqplayer for NAA I see the following
But I am not able to play anything. Any ideas what needs to change?
Apr 26, 2023 at 10:06 PM Post #833 of 2,584
Hi,
try flipping the Red to the other device output and then HQP should show the Red rather than the enhanced. I believe the "enhanced" refers to the i2s interface.
Apr 26, 2023 at 10:08 PM Post #834 of 2,584
Hi,
I don't know what compute you're using but you might not be able to hit that high of a level (48k x512). Try 48k x 256 first.
Apr 26, 2023 at 10:10 PM Post #835 of 2,584
Is it possible to connect 2 dacs to the Holo Red? then select one from the UI to play to that?
All of the outputs(except USB) are active simultaneously, I would guess. I can test this tonight, with coax and optical to 2 DACs.
Apr 26, 2023 at 11:12 PM Post #836 of 2,584
Yes it is. You can plug other dac to usb out and other to aes-ebu/optical/coax/bnc/i2s output.
Apr 27, 2023 at 12:01 AM Post #837 of 2,584
Apr 27, 2023 at 12:07 AM Post #838 of 2,584
For DDC or streaming, I didn't install any drivers, on Windows 10. Maybe I did for streaming/ethernet functionality, but I don't recall doing it... 🤔
Apr 27, 2023 at 1:16 AM Post #839 of 2,584
I already had the Holo Audio driver installed for my Holo Dac before I got the Red.
I get the HoloAudio control panel with which the Red now comes up in it when in DDC mode.
So I thought it needs this driver for the ASIO part for your software players etc?
Apr 27, 2023 at 1:46 AM Post #840 of 2,584
How do you get the ASIO drivers in Windows to select them in the software players?
Can see in my examples that I can select "HoloAudio ASIO driver". This I thought comes from installing the Holo Audio driver.
